-   -   Molykote Substitute and Temp Sensor Tool (http://forums.pelicanparts.com/porsche-911-technical-forum/954085-molykote-substitute-temp-sensor-tool.html)
LUFTKUL 04-21-2017 06:05 AM
Changing out the Temp Sensor on an '84 Carrera. Bentley manual calls for Molykote on the threads. Is Permatex Aluminum Anti-Seize an acceptable substitute?
Also, this special Porsche tool is listed as necessary to install. I was able to remove the sensor by cutting the wire and then using a closed end 13mm wrench. The replacement sensory looks to be 14mm, but I obviously can't cut the new wire. Open ended wrench is too big. Do most people simply cut a slit in a cheap closed end wrench to tighten?
http://forums.pelicanparts.com/uploa...1492779857.JPG
darrin 04-21-2017 06:12 AM
I used a pair of needle nosed pliers- not elegant, but sensor's still doing its job 20 years out
Lyle O 04-21-2017 06:38 AM
Or, get a grinder and slit a socket yourself (that's what I did).
HaroldMHedge 04-21-2017 08:46 AM
I don't think the Permatex Aluminum Anti-Seize would be a good substitute since the Molykote HTP paste is zinc based.
Molykote HTP MSDS, see page 7
The Loctite Zinc Anti-Seize would be a better substitute.
Zinc Anti-Seize
LUFTKUL 04-21-2017 09:19 AM
There has got to be something acceptable that doesn't cost $50/can for one time use.
djpateman 04-21-2017 09:53 AM
Milk of Magnesia
kyngfish 04-21-2017 10:40 AM
Lol
After spending an hour grinding a deep socket perfectly it still didn't work because of the stiff insulation near the sensor. Basically wasn't deep enough. Cut a slit in a cheap closed end of the appropriate wrench like you mentioned. Easy peasy.
HaroldMHedge 04-21-2017 11:45 AM
Luftkul,
Amazon has several products with a better price.
Amazon Zinc Anti-Seize Search
LUFTKUL 04-22-2017 04:08 PM
Complete
The Bosch replacement sensor had Molykote already on it inside the plastic cap covering the threads. Problem solved.
And sometimes Harbor Freight is the answer. This modified wrench made quick work of it.http://forums.pelicanparts.com/uploa...1492902494.jpg
HaroldMHedge 04-22-2017 06:29 PM
Glad to hear everything worked out.
Harold
