Can you help identify this wire and what circuit it goes to
Hi guys - hope Monday is off to a good start for everyone. I feel like even more of a dope than usual but I can't seem to track down what circuit this wire is for.
It is loose at this point. What color would call this? http://i207.photobucket.com/albums/b...psocg41tid.jpg |
Hi Td..search is your answer...have look here..;-)it is front lights related..
Ivan http://forums.pelicanparts.com/porsche-911-technical-forum/170417-fuse-panel-diagram-picture.html |
Blue/white high beam is the likely suspect.
Thanks guys - part of the confusion is that looks blue/light blue to me which I couldn't find on the wiring schematics or searching.
From Proposche's link there is a picture of it being connected to a grey (gray) wire power source which I believe is a parking light. (Hi Dennis!) |
Oh geez - I am a dope. I posted the wrong picture.
Got that blue one sorted, it is headlights. I was actually trying to ask abut a white/blue. Sorry! EDIT - looks like a high beam indicator light powered off the left side high beam from the fused side of the fuse box? |
White/blue is hi beam indicator lamp. :)
It would make sense that the highbeam indicator would be picked up on the fused side of the white high beam power source fuse, correct? |
You need to clean those fuse terminals.
Little wire wheel on a Dremel works wonders. |
| All times are GMT -8. The time now is 01:59 AM. |
