Bilstein rsr with no insert
Hi, I'm looking for a set of insert that will fit those front struts(far right on the first picture). The problem is that I don't know if they are home made of if they are real since the spindle doesn't seems to be raised. Any Idea?
Thanks Émile http://forums.pelicanparts.com/uploa...1493130175.jpg http://forums.pelicanparts.com/uploa...1493130175.jpg |
Are you sure they have not been raised by 19mm?
they are the same height as the bilstein strut next to them on the first picture.
I think it would be worth measuring them. Here is a link that will tell you how;
http://forums.pelicanparts.com/porsche-911-technical-forum/238621-rsr-spindle-height.html Here is a picture of what I think are real RSR front coil overs - it looks like you have the same gussets. 911 RSR Bilstein Front Coil-Over Struts - Photo 4 photo - slidevalve911rsr photos at pbase.com |
I got 3.5 inch instead of the 4 inch shown on the picturehttp://forums.pelicanparts.com/uploa...1493155368.jpg
Lindsey Racing has an RSR Bilstein package. They have 12mm raised spindles. 12mm = 0.472441 inches. That would make it close to them.
12mm may be desirable for someone not wanting wheel weights on the inside of the wheel. https://www.lindseyracing.com/LR/Porsche/911-BIL-RSR-KIT-1.html |
where can i find individual insert to put in those struts?
You will want a Bstein insert valved to the springs. Assuming everything else is a regular Bilstein there will be many suppliers, including Pelican Parts.
| All times are GMT -8. The time now is 09:30 AM. |
