Émilio
Bilstein rsr with no insert
Hi, I'm looking for a set of insert that will fit those front struts(far right on the first picture). The problem is that I don't know if they are home made of if they are real since the spindle doesn't seems to be raised. Any Idea?
Thanks Émile ![]()
Are you sure they have not been raised by 19mm?
Émilio
they are the same height as the bilstein strut next to them on the first picture.
I think it would be worth measuring them. Here is a link that will tell you how;
RSR Spindle Height Here is a picture of what I think are real RSR front coil overs - it looks like you have the same gussets. 911 RSR Bilstein Front Coil-Over Struts - Photo 4 photo - slidevalve911rsr photos at pbase.com Last edited by jamesjedi; 04-25-2017 at 11:43 AM.. |
Émilio
I got 3.5 inch instead of the 4 inch shown on the picture
Lindsey Racing has an RSR Bilstein package. They have 12mm raised spindles. 12mm = 0.472441 inches. That would make it close to them.
12mm may be desirable for someone not wanting wheel weights on the inside of the wheel. https://www.lindseyracing.com/LR/Porsche/911-BIL-RSR-KIT-1.html |
Émilio
where can i find individual insert to put in those struts?
You will want a Bstein insert valved to the springs. Assuming everything else is a regular Bilstein there will be many suppliers, including Pelican Parts.
