-   -   how to remove side window trim to fix rust spot? (http://forums.pelicanparts.com/porsche-911-technical-forum/954585-how-remove-side-window-trim-fix-rust-spot.html)
PabloX 04-25-2017 03:12 PM
I'm not quite sure how this spot happened, but it's surface only. On the other hand, I need to get in there to remove all the rust.
http://forums.pelicanparts.com/uploa...1493158204.JPG
So is it fairly straightforward to remove that trim piece?
Next question, is there a recommended spray touch up paint for Porsche? Luckily the car is black.
Dmitry at Pelican Parts 04-25-2017 03:37 PM
Hi Pablo - check out the link below to our touch up paint section. Please let us know if you have any questions.
Paint & Solvents - Pelican Parts
scottrx7tt 04-25-2017 04:11 PM
It just pops off. You will need to get underneath it with a flathead screwdriver or putty knife.
PabloX 04-25-2017 05:47 PM
Great. Thanks Scott.
OldSpool87 04-25-2017 06:55 PM
Maybe use a plastic trim tool to prevent paint damage.
Dpmulvan 04-26-2017 05:03 AM
Finally bought the proper tool to remove trim et, should have bought one 20 years ago makes life so much easier.
GeorgeK 04-26-2017 05:30 AM
Edit, I was all wrong...
PabloX 04-26-2017 05:54 AM
Link?
I should have also asked, there's two pieces of trim there. One along the glass and one just above the rust spot. Do I need to remove both or will the one blocking the rust spot come off on its own?
Thanks.
shadowjack1 04-26-2017 06:39 AM
http://forums.pelicanparts.com/uploa...1493213841.jpg
Pry up here with a flat wooden stick. Or as I did just use your fingers. Spring type clips hold it in place
PabloX 04-26-2017 06:47 AM
Perfect, thanks.
Now that I know how it comes off, I'll mask up the area before I do so.
