how to remove side window trim to fix rust spot?
I'm not quite sure how this spot happened, but it's surface only. On the other hand, I need to get in there to remove all the rust.
So is it fairly straightforward to remove that trim piece? Next question, is there a recommended spray touch up paint for Porsche? Luckily the car is black.
1986 911 Carrera Coupe 2016 VW Golf R 2008 Toyota Highlander (given to kid) 2021 Kia Telluride 2020 BMW R1250RS |
Administrator
Hi Pablo - check out the link below to our touch up paint section. Please let us know if you have any questions.
Paint & Solvents - Pelican Parts |
It just pops off. You will need to get underneath it with a flathead screwdriver or putty knife.
Great. Thanks Scott.
Maybe use a plastic trim tool to prevent paint damage.
Senior Member
Edit, I was all wrong...
I should have also asked, there's two pieces of trim there. One along the glass and one just above the rust spot. Do I need to remove both or will the one blocking the rust spot come off on its own? Thanks.
1988 Carrera
![]() Pry up here with a flat wooden stick. Or as I did just use your fingers. Spring type clips hold it in place
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Now that I know how it comes off, I'll mask up the area before I do so.
