E brake delete
In the search for eternal enlightenment im thinking of deleteing the whole ebrake setup. I have done some major weight saving on my quest to 2000 lbs. and this should shave off another 7-10 lbs(estimated) I live in florida so everything is pretty flat and i think leaving it in gear would be fine. I could chock the tires if i had to. Has anyone else done this or is this just a dumb idea.
78 911 st backdate
87 944
00 996
Old 04-26-2017, 05:04 PM
steely's Avatar
For daily drivers in PA anyway, we can't get around the state inspection requirement.
FL doesn't have that, do they?
Personally I wouldn't but if she's a racer, I guess could see it, but keep the parts for when you sell it.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-26-2017, 05:35 PM
Yeah no state inspections here and car would be far from passing anyways. Not worried about resale car will stay in the family.
78 911 st backdate
87 944
00 996
Old 04-26-2017, 07:09 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
track car so its long gone, pretty straightforward ripout.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 04-26-2017, 07:26 PM
Administrator
Dmitry at Pelican Parts's Avatar
Check out the link below - although it's for the e-brake adjustment, the process should be similar in disassembly.
Porsche 911 Parking Brake Adjustment | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 04-27-2017, 10:38 AM
Sboxin's Avatar
E-brake remove
We did this when we went to Coil over springs . . . also did rear wheel bearing R/R . . . not difficult but I don't remember if I removed the hub first or not . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 04-27-2017, 12:01 PM
Lol, this is one mod I won't be doing. My Ebrake saved my life at the track after I had boiled mine, was going about 80mph in a long straight away going down hill. The trees where one 100 yards in front of me.
Old 04-27-2017, 12:14 PM
exactly- over the years I have seen multiple people use theirs in a bad situation.
remember, emergency brake, not parking brake.
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 04-27-2017, 12:41 PM
Yup, losing those 7 pounds just could make your car almost fast as a Jetta 2.0 sport wagon with a Labrador retriever in the back.
Old 04-27-2017, 02:57 PM
Thanks not asking how to remove them(they are already off). Just seeing the pros and cons of not having them. You guys made some good points. I guess i have never had to use the e brake in an emergency situation so didnt think about that.
78 911 st backdate
87 944
00 996
Old 04-27-2017, 03:06 PM
Elombard's Avatar
Yeah I had to use mine once when I ran over a thing on the freeway and it ripped off the master cylinder because I had the bottom plate off the car because ...weight savings.
Anyway have you thought about a line lock for an ebrake? I think they are pretty easy to add in. Wont help in an emergency if the hydraulics are compromised.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 04-27-2017, 07:59 PM
steely's Avatar
Actually, it's just a parking brake.
Dan
Venetian Blue
Old 04-28-2017, 02:35 PM
