Help car stays running after pulling key
Ok fellas I just had the retro fuse relays from our host installed today by a reputable Auto electric shop and after picking the car up everything was working fine. I decided to take a quick drive after work this evening but only made it a 1/4 mile when the car just shut off! I pulled into a vacant lot and it fired right up so I figured Id head back to the garage and upon arrival I turned the ignition switch off and pulled the key out but the car stayed running! The only way to shut the car off was by popping the clutch but the pump and alt light stay on so I disconnected the battery.
Please help JR |
What year car? Do you mean the replacement fuse panel with headlight relays?
It sounds like maybe the shop screwed something up or your ignition switch electrical has failed. |
By any chance is your foot on the brake?
https://uploads.tapatalk-cdn.com/201...f95f06f675.jpg Sent from my XT1650 using Tapatalk |
There are no reported issues with our fuse panels and we have over 300 units installed across all model years.
It does sound like either a wiring error or a ground issue. |
Jr Sent from my XT1650 using Tapatalk |
Update
https://uploads.tapatalk-cdn.com/201...f6af0152e9.jpg It's all good Sent from my XT1650 using Tapatalk |
Pull the handbrake up and see it if cuts off.
So what made it 'All good'? Was it 'FM'?
Would that indicate a grounding problem in the emergency brake light circuit? |
Sure would be nice to hear what the answer to the prob was.
http://forums.pelicanparts.com/porsche-911-technical-forum/922938-weird-76-electrical-issue-headlights-engine-wont-turn-off-speedo-light-braking.html |
Issue.
Nothing worse than not posting the resolution to one's posted issue...... Gerry |
I have looked for it on a few cars and have never found it. Doesn't matter anyway, if it's bad it just acts like a normal piece of wire so to speak. You can just splice in a new one behind the gauges.
Reading between the arm hairs, I believe the skullified knife and maybe the watch were lodged into the fuse panel creating the issues. Or maybe it was the key fob, or a comet. Definitely X-files stuff.
