vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Continued Smoke in Cockpit
Ok, so I've posted this issue a couple times already. My latest is to remove the hoses between the heat exchangers and the heater flapper valves, and smoke continues to come into the cockpit via the dash vents. How can burnt engine oil come into the cockpit when the valves are closed and the hoses are disconnected?? There is something I am missing!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 05-17-2020, 03:08 PM
Exactly where are you seeing smoke come in? The "dash vents" (in the center of the dash and to the right of the clock) are for AC only, not heat -- heat (and smoke from heat exchangers) would come in from defroster vents at the very top of the dash, or heater vents below dash, depending on which direction your dash heater lever is set.
Old 05-17-2020, 03:29 PM
vesnyder's Avatar
Smoke is coming in from the center dash vents. I have the AC disconnected so where can the smoke be getting into the system? I need a ventilation schematic. Thanks
Vance
Old 05-17-2020, 03:32 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Smoke.
Darrin is correct.
Hope this helps.
Are you certain the valves are closed?
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-17-2020, 03:40 PM
Harpo's Avatar
You could try sealing off the heater flapper boxes with spray paint can tops.
Old 05-17-2020, 03:51 PM
vesnyder's Avatar
I am pretty sure the flapper boxes are closed. Is there another source?
Old 05-17-2020, 04:19 PM
I suspect your flapper boxes are not completely closed. Common issue. Rob
Old 05-17-2020, 07:17 PM
