Guess the car
First clue
935?
1983 Yugo
crude rudy '84 cab '14 ZX-14R |
Porsche?
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect Last edited by kach22i; 04-26-2017 at 05:36 PM.. |
Looks like an external belt drive oil scavenge pump? Possible an early turbo? single plug?
Very tall set of slicks on those rims. Also see hollow sway bar? Old style turbo black calipers? Not sure what car this is but those are things I noticed? A 935?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
My guess is Porsche 959 w/all wheel drive
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
959 had water cooled heads, these look air cooled? I also thought 959 at first.
959 also did not use those trailing arms or brake calipers. To me it looks like a old school specialty 911 like the 935?
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible Last edited by scarceller; 04-27-2017 at 06:52 AM.. |
gearhead
935
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Air/water cooler
Kugelfisher MFI
'82 SC TL
I think I Think maybe this one? I love 934's
76'S 1st Porsche white/can/can early rebuild (boo) ![]() '84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1) ![]() '87 Carrera cpe white/blue short flirt ![]() '89 Anniv. sil/linen very pretty miss her ![]() '88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
That's the car, What version of 934?
gearhead
With a 962 engine?
'82 SC TL
I don't want to give the spoiler alert on this one myself, but...this particular 934 sold recently at a very "good...." auction at an impressive fetching price
yes it did, but it's far from the rarest or most expensive in the owners stable
no,
The foirst batch of 31 934, had CIS and aluminum cages. This is from the second batch of 10 w/ steel cages and Kugelfisher MFI, the 930/73 motor is +60hp & 500rpm from the original 930/71, retaining the stock air/water intercoolers. It's a fascinating car. The wheel well pic above shows where a street car would have had the gas filler, this one has stock steel 930 fenders but no filler components. The interior is the same blue sliver knit as came in my C3 right down to the door cards.
Forgot to add it's one of 10, 934 1/2 or 934/5 or 934.5
single plug, welded up gas tank pan stock rack and support, no oil air flow funnel thge center lock nut weights nothing , the tool must be 10kg, pin drive & 917 rotors Mg BBS w/ the tires secured to the wheel by 4 screws
trans
Canepa has an aluminum cage 934 in his collection. I must have taken 100 pictures of it last month when I was there.
thanks bill thats fantastic question .. do you think it is safe/ok to run the oil feed line under the axle where they have it on this car? i have just rerouted my -20 oil feed line thru the tunnel. but i was looping it to the top near the starter then down to the fitting which makes a wide berth around the axle. i am wondering this is overkill, and also defeats the purpose of having a relatively straight, level run from the front oil tank to the motor. sorry to hijack this. impt for me right now as finishing my rebild.
best wishes frank |
