What to do with this open port on a 3.2
As part of replacing my micro idle switch I pulled the throttle off (top tip from John Walker), and in doing so discovered that I have an open port. This is taken looking from the rear of the throttle assembly towards.
http://i207.photobucket.com/albums/b...pssctg5mla.jpg What line should connect here? OK to just cap it to make sure I don't have a leak / am not getting false air? Thanks in advance for the help! |
Goes to the valve by your oil fill cap
Ah - thanks.
Bet it is supposed to connect here; http://i207.photobucket.com/albums/b...psp55prx2u.jpg OK if I cap it for now and use the car while I track down a replacement hose and valve etc? |
That is a pic of your vacuum limiter (a simple pcv valve), your air valve should be a few inches up and forward from there.
| All times are GMT -8. The time now is 08:27 PM. |
