Question regarding tail lamp lens gaskets
I am in the process of replacing my tail lamp lenses with Euro lenses. The original gaskets look pretty rough and as a result, I plan to replace them. They look as if they are glued in place ? Any tips on how to remove them without destroying the lamp housing ?
I assume it is necessary to glue the new gaskets ? What should I use as far as an adhesive ?
Thanks,
Ron
Old 01-24-2003, 10:31 AM
nick-moss's Avatar
This subject was covered a couple of days ago here
Nick Moss - RGruppe #318
early911.co.uk
Old 01-24-2003, 10:40 AM
Cool
new lens gaskets can be PIA.. seems they are always to thick. I tried 2 different dealers, SOS..............Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-24-2003, 03:26 PM
Early_S_Man's Avatar
Porsche Crest
3M 8011 Black Weatherstrip Adhesive works very well on those gaskets. Get some 3M Paint Cleaner along with it at your local automotive paint supply store ... to clean up afterwards with, and you won't have to worry about harming your paint cleaning up the bits of adhesive that squeeze out after the lenses are tightened down. Clean it up before it hardens!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-24-2003, 04:06 PM
I replaced the lenses and gaskets a year ago or so on my 1987 and hope to never do it again. What started as a Friday afternoon project took until Sunday to complete. I tried to remove the entire unit rather than just replace the lense. Dumb idea. The screws stripped and replacing them was a nightmare. The new seals are larger than the original but I figure in about 10 more years they'll settle in. Hopefully.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 01-24-2003, 06:58 PM
Cool
thanks for relaxing me...........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-24-2003, 07:06 PM
