1974 911 coupe set for 10 years with fuel in tank
hello I have just purchased a 1974 911 coupe. Per the owner the car ran fine before storing it in a garage for 10 years with fuel left in tank. I need to know the best place to start. I want to mechanically go through the car and make all mechanical systems work properly before body work and new paint job Any recommendation would be great
Old 05-01-2017, 08:03 PM
gearhead
Welcome to the board. Rule number one, any proper introduction require a few pictures of your car. Please?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-01-2017, 08:05 PM
Functionista
manbridge 74's Avatar
Stored in cool temps? You might get lucky.
How much rust?
Include some engine pics.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 05-01-2017, 08:42 PM
Yeah pictures are a necessity! Welcome to the mid year club.
Chris
'75 911s Targa
Old 05-01-2017, 08:59 PM
Bill Douglas's Avatar
Hi Jim.
Wayne's 101 project book and the Bently book will prove invaluable. Even the Haynes manual.
Old 05-01-2017, 09:25 PM
HarryD's Avatar
Check post 21 in this thread: Winter storage checklist?
Grady has posted numerous times on getting a stored engine/car back on the road. Ignore his advise at your own risk.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 05-01-2017, 09:45 PM
Grady should write a book.
Old 05-01-2017, 10:20 PM
HarryD's Avatar
In a manner of speaking, he did. Sadly, he is no
Longer with us.
Harry
2020 MB E350 4Matic
Old 05-01-2017, 11:16 PM
Sorry, I didn't know.
Old 05-01-2017, 11:39 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hi Jim - welcome to the forums! I've attached a link to our site's DIY tech articles for your 911. The articles are broken down by section and are easy-to-follow guides to everything you may encounter when doing maintenance or troubleshooting any issues. Please let us know if you have any questions!
Porsche 911 (1965-1989) Technical Articles - Pelican Parts
Old 05-02-2017, 10:19 AM
HarryD's Avatar
I did not intend my comment to be a slam on you. His passing was sad but he intentionally left us a great legacy so in one way, he lives on.
Harry
2020 MB E350 4Matic
Old 05-02-2017, 02:59 PM
gearhead
Truth.
He did want to write a book, but it just never happened. But we do have his "archives" here.
1974 914 Bumble Bee
2009 Outback XT
Old 05-02-2017, 03:08 PM
RETIRED
Joe Bob's Avatar
Ran fine before stored. Yeah, one of the better lines out there.
Rots a ruck.....change all the fluids, get a knowledgeable friend, have a fat wallet.buy a Bentley manual....
2012 ML350 3.0 Turbo Diesel
Old 05-02-2017, 06:18 PM
First thing is to drain all that stale gas. Do NOT try to start it before introducing fresh gas as you'll move crap all through the system. Install a new filter. I'd drain the tank, then take off the fuel sender. Peer into the tank with a flashlight & inspect the sides with your finger. If you see rust, you'll need to flush the tank or even have it blasted or chemically cleaned. On my '88 which sat with bad fuel for about 10 years, I had to replace the tank as it was too far gone along with the injectors. You will no doubt want to examine the fuel lines, then move on to replacing plugs. Fresh oil & filter, and new battery then see if it goes. Good luck.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-02-2017, 06:28 PM
gearhead
Definitely don't want to send any of that crud into the fuel distributor, though it will probably need to be cleaned and/or rebuilt anyway.
1974 914 Bumble Bee
2009 Outback XT
Old 05-02-2017, 06:37 PM
Old 05-02-2017, 07:38 PM
thanks for all the input! I will definitely purchase the books mentioned. I have attached a few pics as requested
Old 05-02-2017, 07:42 PM
RETIRED
Joe Bob's Avatar
That's a keeper. Don't cheap out on the windscreen area rust. Pull the windshield and do it right. Great color, same as mine.
Learn to drive it before any upgrades. IF YOU DO feel the urge, suspension first. The engine will wait. It's a momentum ride not a drag racer. Carve the corners leave the wankers in the dust.
Welcome to our nightmare....
BTW, learn how to check the oil on a dry sump motor. Also, it's 12 quarts so hold onto your shorts. Have a BIG catch can.
Old 05-02-2017, 07:43 PM
listen to joe bob he is the man!!!
Old 05-02-2017, 07:58 PM
gearhead
Nice.
1974 914 Bumble Bee
2009 Outback XT
Old 05-02-2017, 08:18 PM
