Uncertifiable!!!
Clutch Suddenly Gave Up
The car has been driven around the block several times since finishing the build. Grearbox shifted nicely up to third and clutch operated as it should. Well, Tried to back out of the garage and clutch suddenly gave up. Could not get it into any gear-just ground the gears as if the clutch was not depressed at all.
Background: Clutch is almost new. Clutch cable is new. Everything else, I.e. clutch fork, trani etc. came out of the donor car. I just inspected and cleaned everything up before reassembly. Trani was not opened up-just replaced the oil with Swebco. So I re-traced all my initial assembly steps: 1. inspected pedal assembly and front linkage in tunnel. 2. checked clutch cable seating at rear by tunnel. Cable sheath makes a nice metal sound against the clutch tube in the tunnel. 3. re-checked cable basic adjustment with cable disconnected at 1.2mm. 4. Re-set cable pre-load with cable connected at 1.0mm. 5. Re-set clutch release distance to 25.0mm (stop on floor board). With the rear wheels off the ground, it will go into any gear if, and only if, the rear wheels are freewheeling. If I apply the brake pedal while I try to put it into gear with the clutch depressed, then it just grinds away. I'm getting the feeling that the clutch fork has bent or dislocated itself from the pilot bearing. Any ideas? BTW, I have also posted this issue in my build thead but would appreciate posting any replies/comments and suggestions here. Evolution of a Carrera RST Thanks in advance. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
I'm going to go with the fork on the TOB broke on the bottom finger.
Bruce |
Member 911 Anonymous
^^^+1 "donor fork"
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Double check the roll pin that holds the clutch pedal to the shaft of the pedal cluster- if that sheared, the pedal will move without pulling the cable.
Rutager West 1977 911S Targa Chocolate Brown |
Happened to me last week, started to judder, adjustment went out. One prong of the fork was split.
www.classicretrofit.com |
on the road... |
Uncertifiable!!!
Thanks Johan
Ah man, sorry to read that. It would have been a easier fix :-(
Uncertifiable!!!
Jonny and Tom,
When one prong of the fork broke on your cars, did the other fork pop out of the pilot bearing groove? Any noise or rattle? Johan
OP, if I may, when the car is cold, have a helper press the clutch and then you reach into the gear box on top at the inspection port with your fingers locate the fork which will be on top of the TOB.
You can feel if the fork is moving or not, you may also feel the fork if it is fractured on top.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 08-01-2016 at 06:01 PM.. |
just no function of the clutch, no gear go in...
on the road... |
Mine split the other end from Tom's (near the splined hole). I could still just about drive the car after the cable was readjusted. Judder was awful. The prong didn't come out of the groove. The top prong went btw.
Managed to get home from 100 miles away!
Uncertifiable!!!
Ok guys, thanks for sharing my pain!
Not admitting defeat, I unhooked the cable from the release arm and got nice solid and smooth pressure when I moved the arm with the aid of a long screw driver. So, I then examined the arms and noted that the small one had a 1mm indentation where the adjustment screw rests. So I filed it off so I would get a better gap reading. I then reassembled and adjusted the gaps, tested the shifter before starting, started the motor and tried to shift-sounded like a first timer changing gears in a Model A crash box. I would assume that since I still have clutch plate pressure at the release arm, the fork must be hanging on to the pilot bearing by one prong. Tomorrow I'll drop the motor and trani and we'll no doubt have a surprise. Cheers, Johan
Uncertifiable!!!
Just trying to remember where the inspection port is on the 915 bell housing. Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 08-01-2016 at 08:29 PM.. |
LOL, have use two feet like my wife does
![]() ![]() 2nd Yellow Arrow
This was my guilty party and why I say you should "never" do clutch removal without replacing this part - obvious exceptions are people who have their engines out regular and know the condition of their part. These are a known failure part. I had my clutch apart and failed to replace this then got to redo the entire job just a couple of months later. Call it an education.
Uncertifiable!!!
DRACO, camera provided limited view. Could only see the end of the top fork arm which looked ok.
I would not have been able to see a crack such as Mr. DIY's example above. Engine almost out but happy hour called. D-day today. Anybody know if there is a basic procedure to test trani on the bench without having to take it apart? Cheers, Johan
Uncertifiable!!!
Cracked clutch pressure plate.!!!
Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant Last edited by Uwon; 08-03-2016 at 10:41 AM.. |
cracked pressure plate .. why were you in there in the first place ? was it an engine rebuild ?
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
WTF? How does that happen?
