jmz jmz is online now
jmz's Avatar
Help! Why would my tachometer needle move when I hit the horn
A couple things going on here when I turn the wheel the horn won't work sometimes I read up on the side about needle bearings in the steering column but why would my tach needle jump?
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 05-10-2017, 12:29 PM
proporsche's Avatar
Hi Jay
in both cases you are loosing your ground to the steering shaft.For the hron to work properly you have to have ground.
I used to fix it like this.let see if i can explain.
In your front trunk compartment is a lid.When you open it you can see the steering joint and a shaft.
I used to put on the shaft additional ground .I cut my self a old feeler gauge about 3 cm long punch a hole in one end and the other end i let touch the shaft like a brush.That will give you additional ground.
That is how i used to fix the horn problem in the 1980`s.Someone might have a better idea.
The tach is jumping also because of bad ground...
Ivan
Old 05-10-2017, 01:09 PM
Hi
Targa Me's Avatar
What he said.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 05-10-2017, 02:06 PM
jmz's Avatar
Thank You for that... I'm still a bit surprised and confused how pushing the horn button causes the tach needle to bounce. ...just ever so slightly.
Old 05-10-2017, 02:28 PM
I thought it was because you scared it when you hit the horn. I guess you learn something every day. Yes, the lame sense of humor comes with age. . .
Don Newton
“People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.”
"I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams
Old 05-10-2017, 08:28 PM
dwight45
dwight45's Avatar
The horn is good for another 5 horsepower.
Old 05-11-2017, 09:03 AM
jmz's Avatar
Haha... Good ones.
Old 05-11-2017, 10:29 AM
proporsche's Avatar
Jay..since you are confused ..have you checked the ground under your steering wheel?? If you remove the wheel there should be cable attached to the little screw on right bottom...
I am telling this just in case you are wondering;-)
Ivan
this one
Old 05-11-2017, 01:34 PM
jmz's Avatar
Ivan
this one
I'm going to check the ground I'm sure it needs help. I just didn't think the tach shared any ground connections with the horn so was wondering about that specifically.
Old 05-11-2017, 01:37 PM
It's important to chase that short down. There's a lot of unfused circuits behind the dash, specifically around the dash lighting. You can get a big fire and wiring meltdown. Pretty common on these 911's. I have first hand experience ...
Old 05-11-2017, 01:52 PM
Troll Hunter
You've got one helluva heel toe action going on if you can hit the horn and the accelerator at the same time with your foot.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 05-11-2017, 01:55 PM
