I think I've got a buyer for my 3", single-outlet Monty. I advertised it because my mechanic once said that the Monty is too restrictive. But people are now telling me that the OEM mufflers are the best for MFI engines -- less back pressure?
I was under the impression that a twin-outlet Dansk -- or even megaphones -- would do the trick. Can anyone tell me what muffler would be a perfect match for my engine? For those who don't know, I have a 911/83 engine (RS 2.7; MFI), but with 11.3:1 JE pistons and GE-60 cams. Matt Holcomb MFIWDP PRVC BOHICA 1974 911 Carrera 2.7 RoW 1974 Ford Falcon GT coupe Dedicated Homepage Engine Rebuild Homepage Porsche Owners Gallery Profile Pelican Gallery Profile |
drag racing the short bus
Matt:
From what I've heard concerning MFI engines, the stock muffler is what should ultimately be used. Anything else could involve idling problems, lack of low-end torque, among other issues.
However, I don't know how that might apply to your engine since it's been so heavily modified (over a stock 2.7 MFI). Maybe you might want to try a stock MFI muffler first, see how things run, and if it seems too restrictive, modify the muffler with a second outlet to see if you get any more power. Or rig up a similar exhaust to those used on 2.8 RSR engines. That might work if your engine has close to the same specs as they.
The Terror of Tiny Town |
dd74,
Dansk make a replica RSR, twin-outlet muffler. I think I'll give one of those a try, first. Thanks for the reply. Matt Holcomb MFIWDP PRVC BOHICA 1974 911 Carrera 2.7 RoW 1974 Ford Falcon GT coupe Dedicated Homepage Engine Rebuild Homepage Porsche Owners Gallery Profile Pelican Gallery Profile |
Metal Guru
Re: Matt:
Less backpressure is better, period. Matt, there are a lot of positive statements posted here on the bb about Monty stuff. I'm sure there are Monty detractors, too. About the only way to be sure you have a low backpressure muffler is to make your own.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
I don't take notes on MFI stuff.. but I believe some restriction in the MFI muffler is important.. plenty of guys around here know about this.. and the Monty is less restrictive on a MFI than what's needed.. gotta keep bumping till at least Monday .............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
It amazes me how the "old wives tales" live on long after the old wife has died!!
Since when is back pressure good? Engines run best when the cylinders fill with nice fresh gas/air mix.....not when half the jug is filled with old burned exhaust gases. But...if you guys insist on cutting down on horsepower and torque for the sake of old wives....far be for me to interfere....LOL Bob
Bob Hutson |
I still beg to differ....
If you were to put the engine on an engine dyno....and test in the condition as if the beast were still in the car (pipes stock size and length)...you would find it's not the back-pressure that gives the flat spot...but in fact a reduction in scavenging at that RPM. I concede that it is very subtle...and most ppl do not have access to equipment with a fine enough variance to get it correct...but persistance pays off. I usually cheat...by looking at what the factory did with their racing engines (they had lots of $$).... It's a small point really....and it breaks down to what you can afford...and what you like in the way of noise. This should get a large response....LOL Bob
Bob Hutson |
Schleprock
Since I don't know diddly about MFI.........
Here you go. Tasteful looking San Diego Chargers cheerleader from a wacky football webpage: ![]()
Kevin L '86 Carrera "Larry" |
Uh, legal? In what country or locality? "Community standards". you know....
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Formerly bb80sc
Matt, how about this one from AJUSA good reviews on the boards and a good price.
http://www.ajusa.com/cgi-bin/inventory/view_product?prod_id=0000000035&part_number=AJR 100 184 They also have one in SS.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Formerly bb80sc
Whoops, sorry for posting off topic folks, I thought this was a muffler thread. Obviously I was wrong
In a perfect world....and I do mean PERFECT...all engines would perform to the top of the chart.
Unfortunately...the world is flat...no wait...wrong subject....I mean the engine is flat...no wait...the engine has flat spots in the torque curve...yeh...that's it. OK...if the cylinders filled with fresh mixture every time....and the ignition was firing at just the correct micro second every time....and the exhaust was scavenging correctly at every RPM range....then we would all be happy. In fact none of that really happens....and it's because of those cheerleaders....or something....we have to blame it on something..and it's certainly not our fault. We slave to keep these little beauties running to the best of our abilities....so now we can blame the darn cheerleaders.... What was the topic again? Those pictures have rotted my brain....LOL Bob
Bob Hutson |
[QUOTE]Originally posted by Matt Holcomb
[B] Can anyone tell me what muffler would be a perfect match for my engine? For those who don't know, I have a 911/83 engine (RS 2.7; MFI), but with 11.3:1 JE pistons and GE-60 cams. Matt Holcomb Hey Matt,... don't know the answer.. way over my head.. but when I was eyeballing mufflers,[ before I decided I wanted a Monty, LOL ] I found this shop in California, US that had a big rep with mufflers.. I would contact Pressler Parts and see what Happens .............Ron
