Send a message via AIM to 82SC
This can't be good...
well as my project proceeds forward at a snails pace because of all these problems popping up...
This is the tubing of the CIS system...I don't even know what it does but I am assuming it is not supposed to have this gaping gash in it...
I am assuming 20 years of contact has worn this part through...
any one have one of these lying around...
shown are pics of the wear and the part of the shroud that there was contact with
Old 01-05-2003, 02:12 PM
Kevin Stewart's Avatar
Wow glad it wasnt fuel, Kevin
Old 01-05-2003, 02:25 PM
Senior Member
Doug Zielke's Avatar
Just had a look at my motor (which is still out of the car), and that pipe should not be rubbing on anything. Check for broken/missing support brackets. It appears yours was rubbing on the oil cooler air shroud.
If you can't find a replacement pipe, you could repair this with a little metal patch and some silver solder.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
patch with what??
any suggestions?
MJ
Old 01-05-2003, 03:13 PM
Patch it with a rubber hose, cut so it slides over then radiator clamp it, but you really should replace or send it to a aluminum welder to have repaired, but you know there is some killer glue that body shopes are glueing metal panels on with, that may be an idea an aluminum patch, Kevin
Old 01-05-2003, 03:19 PM
Elombard's Avatar
Could this part be replaced with a couple of rubber hoses and a vent to air?? I was thinking it would make it a little easier to get in there and work on stuff?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-05-2003, 04:58 PM
crikey, that's an important air line. that gap would have made the car run and idle poorly with high HC. find a good one, or weld in a patch. this is a fairly common problem, but not easy to find due to the location.
206 637 4071
Old 01-05-2003, 05:23 PM
got a new one...
but the clearance is still pretty close...anyone tell me how far it should be from the shroud??
MJ
Old 01-24-2003, 06:51 PM
if you can get 1/2" clearance once it is mounted in place,that will do it. Be careful bending it around to accomplish this- you don't want to misalign the connections or break the replacement!
btw- saw a sample panel painted with that early yellow /orange at Kevin's. Awesome choice if you go with it
Old 01-24-2003, 07:12 PM
marcesq's Avatar
MJ:
Cut a piece of breather or fuel hose with an inner diameter large enough to fit around the pipe. Slice the hose lengthwise and put it around the pipe at the point of prior contact like hot water pipe insulation. That should do the trick for future preservation.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 01-24-2003, 07:24 PM
As soon as I saw the pictures, the first thing that came to mind was JB weld. What a perfect opportunity to try it out. It would cure to a nice grey color to match the aluminum.
Cheers,
Joe
Old 01-26-2003, 11:26 AM
