Dumont's Avatar
Radar detector
Just wondering if anyone has a clever mount/power routing for their radar detector.
I'm using a V1 and was just about to run the flat cable today (so far have just been using the coil straight from the windshield to the lighter socket) but ruined the cable so I'm rethinking it.
I really don't like a couple things:
1. routing the flat cable between the headliner down the A pillar under the dash edge seems kludged to me, but it looks OK when done well
2. Frankly I hate the detector in my face all the time. One of the reasons I like the 911 is the expansive view (I don't have my rear mirror mounted). At the very least I'd prefer to detector to sit close on on the dash but I know the manufacturers recommend high mounting. Anyone have any experience otherwise?
I am wondering if there any clever alternatives.
79' 911sc
Old 05-06-2017, 07:25 PM
Banned but not out, yet..
RSBob's Avatar
No ultimate solution with my V1 either but this is what I did.
1. Used the hard wire kit rather than the lighter attachment. Tapped into an ignition switched wire for the disconnected rear window defroster (red with white stripe). Ran the flat wire under the dash up the side of the glove box and up the inside of the passenger A pillar.
2. The detector lives on the passenger visor and does not restrict my vision or get in my face. When the auditory alert sounds, then I check out which arrow is illuminated.
Not a great solution but it works and the detector switches off and on with the ignition.
Old 05-06-2017, 08:21 PM
El Duderino
tirwin's Avatar
I use Escort Redline and the direct wire (DW) Escort Live remote module. I ran a Cat3 wire down the passenger A-pillar to make my own Escort cable. The remote module is mounted under the dash.
Check out a company called BlendMount. When I replaced my windshield I used a rear view mirror with HomeLink buttons so I could ditch the garage door opener. The BlendMount attaches to the rear view mirror and the radar detector connects to it. They have Valentine and Escort mounts.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 05-06-2017, 09:38 PM
Tread hijack to plug the Waze app - no affiliation other than a convinced user, and a great companion to a radar detector.
Chuck.H
'89 TurboLookTarga, 432k miles
Old 05-08-2017, 04:46 AM
Mitsos's Avatar
I hardwired mine in to a accessory wire (on when engine is running)and had a permanent mount on the windshield.
The V1 sits right above the mirror out of the way but with great exposure to road.
Will send photo if you wish.
Old 05-08-2017, 07:14 AM
Please show a picture.
Ravi
1974 914 2.0
1975 911s 3.0
2014 Cayenne GTS
2016 Cayman GTS
Old 05-08-2017, 07:25 AM
Dumont's Avatar
Yes, photos in the thread would be great.
79' 911sc
Old 05-08-2017, 07:49 AM
I use an escort Qi45 in my 1973 911 has laser shifting too.
Remote head and tiny control on dash.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-08-2017, 09:25 AM
Tori's Avatar
Chuck.H
+1 Waze and Escort Max here. Keep the Waze app open, with the radar detector running and talking to me in the background.
My Escort is hardwired via their flat wire and mounted to a Escort windshield sticky mount right above the mirror.
1987 911 Carrera Coupe
1987 Buick Grand National
1971 Plymouth Roadrunner
Old 05-08-2017, 11:32 AM
I'd also like to see a photo. If you could show which wire you taped into as well, that would be great.
Old 05-08-2017, 01:57 PM
I do not hardwire radar detectors, as it is known that hardwired units are a burglars' magnet. I have a small flat RJ11 flat cable and position the V1 low over the dash. When I leave the car I stash the V1 and the small cable in a hidden location.
Old 05-08-2017, 04:08 PM
Dumont's Avatar
It's pretty hard to find slim line rj11 cables
79' 911sc
Old 05-08-2017, 06:28 PM
What do you mean? Flat RJ11 line (black) is available everywhere. Cut it to size and crimp an RJ11 connector at either end.
Old 05-08-2017, 08:24 PM
Dumont's Avatar
Well I'm looking for super slim which is available but harder to find
79' 911sc
Old 05-08-2017, 09:04 PM
Formerly known as Syzygy
Canada Kev's Avatar
Do you mean just two conductor cable? I don't believe I've ever been it for sale anywhere. The four conductor stuff is already pretty small and easy to hide.
Kevin
Old 05-09-2017, 05:00 AM
Dumont's Avatar
No I meant 4 conductor. I've bought super slim cable in years past but now that rj11 has so little use it's becoming harder to find.
79' 911sc
Old 05-09-2017, 05:20 AM
cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
x2 great solution
Old 05-11-2017, 04:56 AM
kuehl's Avatar
Escort 9500iX
Used a common mirror mount.
Hard wired to the light.
No problem with visibility or hitting the mute button.
You can yank it down quickly when you find you were not quick enough!
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 05-13-2017, 12:48 PM
Dumont's Avatar
Can you elaborate on the light hard wire?
79' 911sc
Old 05-13-2017, 09:55 PM
kuehl's Avatar
Many of the radar detectors have available aftermarket mounts and 'hardwire' kits.
Since I'm not using the cig adapter cord that came with my unit, I simply
tapped off the interior light over the mirror, rather easy to do. And this model
detector shuts off automatically after so many minutes of non activity so I don't have
to worry about battery drain. If I get a chance I'll take a pic of the how I wired it to the light, again, easy stuff.
Kuehl
Old 05-14-2017, 03:12 PM
