Can anyone explain how to test the oil temperature sender?
76' 911. Oil pressure side of the gauge works but the oil temperature doesn't. It rises slightly from dead bottom when I turn the car on but doesn't do anything after that.
I want to test the sender but I don't really know exactly how. Also, is there a way to test the gauge or a place to send it?
Thanks.
Old 05-24-2017, 09:44 AM
T77911S's Avatar
remove wire, check gauge. short wire to ground and check gauge. should be max deflection one way and min the other. if so then sender is bad.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-24-2017, 10:59 AM
Send a message via Skype™ to Porboynz
Boiling water is 100C
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 05-24-2017, 09:53 PM
Subd
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 05-24-2017, 10:33 PM
