Can anyone make a heating crossover pipe that will fit Fabspeed headers?
I am looking for something similar to the crossover heating pipe in this picture.
Can someone make me the same thing? If so... please PM me with payment info and such...
1987 Porsche 911 Carrera Coupe
Old 05-17-2017, 01:39 PM
The 9 Store
PM - MB911 he can do it if he has time and you have money. :-)
All used parts sold as is.
Old 05-17-2017, 01:50 PM
Thanks... will do!
Old 05-17-2017, 01:51 PM
Bill Verburg's Avatar
Aren't they designed to use the stock 3.2 or 964 parts?
Bill Verburg
Old 05-17-2017, 02:39 PM
When I bought their RSR kit, I thought they did come with everything I need... but it seems their Carrera RSR kits w/ heat are not designed for 1987-1989 Carrera 3.2s.
I was told by Fabspeed that I would need to modify their part made for a different model car to make it work.
Would rather just fabricate the entire thing.
Old 05-17-2017, 04:52 PM
I can do something for you but would need templates and or drawings.
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 05-18-2017, 04:00 AM
Just an idea. Can you cut the crossover that you have and reconnect with high temperature hose and clamps?
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 05-18-2017, 04:27 AM
Good luck,
Dave
That's what Fabspeed suggested I do... which I will try it out.
Not ideal, but would eventually want something that looks a little less 'redneck' and a little more refined and professional.
Old 05-18-2017, 05:20 AM
There are 2 different heat crossovers that were used on 3.2 thru 964
1) the 3.2 version w/ round inlets
2) the 964 version w/ oval inlets
This appears to be using a 964 version
I have B&B headers and used a 964 heat, hard to believe that Fabspeed wouldn't have done the same sort of thing crossover
Bill Verburg
Old 05-18-2017, 05:37 AM
michael lang's Avatar
That's what I would do. With carefully selected placement of SKEET you should be able to avoid the "redneck engineering".
Mike
'89 CARRERA
#402
Old 05-20-2017, 01:12 AM
