Weaver's Avatar
HAHAHA! The new Toyo R888r 205/55 is...
efing huge!! Looks like a damn ballon...
Tire Rack said I was the first person outside Cali to purchase the new 205/55-16, the second person overall from Tire Rack. Kinda wish I would have waited until I'd seen them on another car.
The 245/45s are the exact same size, same specs as the Michelin Sport Cups I took off, but the 205/55s are larger than any other 205/55 I've ever owned, Michelin, Bridgestone, Dunlop.....Tire Rack doesn't even have the spec of this size listed, and the Toyo website spec sheet is empty. I guess I mistakenly trusted the size listing.
Guess I'm gonna get a pair of the 205/50s and see how those are.
Weaver
'88 911 Targa
'03 911 Turbo, X73 Susp.
'13 Panamera GTS
PCA member Central Indiana
Old 06-09-2017, 10:34 AM
3 restos WIP = psycho
kenikh's Avatar
Doesn't look that bad in the pic
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-09-2017, 10:40 AM
Yeah that looks great, just need something similar in back to match.
Matt - 84 Carrera
Old 06-09-2017, 12:12 PM
To me, it looks fine.
I guess it is all in what you are used to.
FWIW, this is the size I run on mine and I like the look. Running Continental DWS.
I don't really like the look of super low profile.
Craig
77 Ice Green 911s w/3.0
Old 06-09-2017, 12:13 PM
1988 Carrera
shadowjack1's Avatar
To me it looks good. Should ride a little softer???
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 06-09-2017, 12:22 PM
Armed Bastard
djb25's Avatar
I dunno - that tire does look awfully tall. It's not a 205/65, is it?
Damion
'77 911S Turbo, EFI 2.7l, Carrera intake, Megasquirt 3 with MS3x, Fuel & Ignition
Old 06-09-2017, 12:48 PM
Toyo R888 and R888R's are 10mm wider than what they spec them as, so a 205 is actually a 215
Old 06-09-2017, 01:44 PM
I don't mind the look. I think the fatter side walls are most appropriate for our cars IMHO.
84 911 Targa Carrera currently getting renewed
Old 06-09-2017, 05:40 PM
kenikh's Avatar
I dig it
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 06-09-2017, 05:42 PM
DanielDudley's Avatar
Sometimes manufacturers use one casing size to mold more than one tread width on, or so I have heard. If your tires clear your wheel wells and the car handles well, I wouldn't worry too much.
Old 06-10-2017, 05:31 AM
The Dude abides...
bigel's Avatar
Then it's not really a 205, right?
It's frustrating when inducstires decide to stray from the original confines of measurement...reminds me of framing lumber, a 2x4 is actually 1.75 x 3.5 and yes, I understand the history regarding that change.
'03 Carrera 4S
Old 06-10-2017, 05:52 AM
Bill Verburg's Avatar
So what are the actual OD & SW & TW measures?
A generic 205/55 x16 would be 24.9", 8.1" & ~7.4" respectively
Bill Verburg
Old 06-10-2017, 06:07 AM
I have done tire design (in plant, not initial design). Green tire (uncured) diameter and width are critical. No way you mix tire sizes in a mold.
Old 06-10-2017, 08:35 AM
This is correct. That 8.1 is section width which is the widest part of the tire when measured on a specified rim (manufacturers rim spec) width.
Old 06-10-2017, 08:38 AM
safe's Avatar
Nah, Toyo 888 205 is usually very near to 205mm, other manufacturers are often narrower. For example I had a set of Yokohama 225 that I measured to 210mm, sucks.
I think they look great on the car!
Magnus
Old 06-10-2017, 10:05 AM
Go to the manufacturer's website and find the specs, then share them with us. If the size is out of line with previous versions, return them to TireRack, then source the correct versions from another Vendor.
Old 06-10-2017, 05:59 PM
The generic rim width is 7" for the example I posted
Bill Verburg
Old 06-10-2017, 06:02 PM
Kind of Blue
MrBonus's Avatar
I've had a similar experience with Dunlop Direzza tires. The ones I bought to replace the same sized Michelins I had on my 911 are far meatier.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 06-10-2017, 06:15 PM
Bill Douglas's Avatar
Certainly the bigliest 205 I've seen. And I like it. Everything about he car is looking really good.
Old 06-10-2017, 09:37 PM
Banned but not out, yet..
RSBob's Avatar
Originally Posted by kenikh View Post
I dig it
What my esteemed colleague from the great state of Washington said.
Old 06-10-2017, 09:46 PM
