1987 911 brake pedal
I like to rev match when I down shift. Two months ago I got a 1987 911 and am in the processes of sorting her out. With the brake pedal depressed all the way I still cannot reach the accelerator pedal. Is there an adjustment that can be made? Should I up grade the pedal box? Opinions and advice please?
Old 05-10-2017, 05:12 PM
ejp ejp is offline
ejp's Avatar
Change your technique. As far as I know, there isn't a lot of adjustability in either the brake or clutch pedal - and I have never had a problem with a heel and toe in G50 cars. The only other alternative is to go with a fat gas pedal kit.
-Ethan
Old 05-10-2017, 05:25 PM
cashman's Avatar
remove the rubber pedal covers
buy a used gas pedal and attach it on top of the existing one
put a washer under the right side of the gas pedal to tilt it toward the brake
done
You can adjust the brake pedal but you will lose travel. There will be a time that you wish you had more travel
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 05-10-2017, 06:39 PM
emac's Avatar
Damn-- I hope you don't have to drive more then a few blocks like that--
Ernie
Old 05-10-2017, 07:01 PM
There is plenty of adjustment possible on the brake pedal. Pull the floorboard and you will see the brake shaft (that connects to the booster) has an adjustment. Loosen the lock nut and adjust away. You will be able to move the pedal position quite a bit
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 05-10-2017, 07:04 PM
cashman's Avatar
Ernie
Not as drastic as it seams. Drives on the street no problem. Heel and toe is still a slight stretch with the mods. No issues what so ever. I adjusted the brake pedal before. Sucks when you're going 120 MPH into a 30 MPH turn and you wish you had another 1/4" of travel.
Old 05-10-2017, 07:14 PM
Cory M's Avatar
There's an adjustable rod behind the accelerator pedal. It has a ball on the end that snaps into the back of the pedal. Pull pedal forward to pop it off, adjust, snap back in, and you're done. Super easy.
Old 05-10-2017, 08:10 PM
Same situation as you.
I plan on buying the Rennline adjustable pedal kit. That way I can practice my heel-toe technique more.
1987 Porsche 911 Carrera Coupe
Old 05-11-2017, 07:11 AM
ganun's Avatar
Do this for a lot less and see if it works for you, 1/8 aircraft ply , screws and rubber covering.
Moving it closer with a spacer and tilting in addition should get you where you want.
Adjusting the brake pedal is a bad idea, you'll loose pedal travel and feel.
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 05-11-2017, 11:37 AM
I made a cover for my gas pedal that makes it wider and screwed it to the pedal with spacers to bring it 1/2" closer. In the end it matches the Rennline floorboard pretty good. This plus a little brake pedal adjustment means toe and heel is PERFECTLY simple.
It's so easy to use I blip the throttle on virtually EVERY downshift.
A real beefy clutch stop like in Georges picture above I also find very helpful - you want to be able to mash the clutch and know for sure when it's fully disengaged.
Chuck.H
'89 TurboLookTarga, 433k miles
Old 05-12-2017, 04:54 AM
Bill Verburg's Avatar
A device like this sure helps
Bill Verburg
Old 05-12-2017, 05:19 AM
Diss Member
Quicksilver's Avatar
There is a vertical rod connecting the brake pedal up to the master cylinder that can be adjusted plus the accelerator and be adjusted. I wouldn't go nuts on them though.
I'd be interested in seeing your technique as I have never seen a car that I couldn't heel-toe in.
Most people that I've run across that have issues with heel-toe are trying to press the brake with the center of their foot. To be truly adaptable you need to be pressing it with the ball of your foot under the big toe. Plenty of great drivers don't do it this way and it isn't "wrong" but it limits versatility.
- Very important! - Working on changing a reflexive skill like braking can be dangerous. You are using you conscious mind to alter something that you always do unconsciously. This makes for mistakes and braking mistakes can become really really bad. Parking lots, empty roads and no threshold breaking for a while, is the order of the day.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-12-2017, 07:42 AM
We made a few different pedal that adjust and have either 15 degree (standard) or10 degree angles.
Old 05-12-2017, 11:41 AM
Yeah I am thinking of doing the very same thing. Just went on line and saw the 4 pedal set. If you do this could you email me at Nextjato@aol.com and tell me what you think? Did it work?
James
Old 05-24-2017, 03:20 PM
