need help ID'ing this engine case
Anybody happen to know what a 930.101.104.3R is off of. I have two carrera 3.0 motors one thats a sporto the other not and their case numbers are identical to above but end in 0R and I have 3 Euro SC 3.0's that all end in 4R. Cant seem to figure what engine would have ended in 3R? This is in a '77 Carrera 3.0 that has had its engine rebuilt and the case with this part number is blank, no serial number no type number.
Old 05-25-2017, 09:58 AM
proporsche's Avatar
Hi there ..use the search button and you will find you answers...
The engine numbers are on the right side of the engine next to the oil pressure sending unit.
Ivan
here
Old 06-04-2017, 12:44 AM
pete3799's Avatar
May be a 914- 6 case..... but I'm no expert.
Pete
79 911SC RoW
Old 06-04-2017, 05:23 AM
gearhead
Nope. 914-6 are based on the 69T mag case 2.0 castings. 930 part numbers didn't come out for another half a dozen years.
Post pictures Nathan. And pm Bill Verburg and ask him to comment. If it's a C3 case it's quite valuable. You should be able to find a casting date. It will be a week and a year inside a circle.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-04-2017, 08:11 AM
Registered Minimalist
75 911s's Avatar
I remember the OR being a Casting number. When I swapped out my chain tensioners they had a what I thought was a part number that ended in OR and I found out are actually casting numbers. Turbo motors would start with 9307 if it was a 77 or 9305 for 75 etc.
My red book has a big blank for engine serial numbers for 77 carrera 3.0 sporto numbers.
The 77 Carrera 3.0 US are 9117600001-9117601473
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-04-2017, 08:56 AM
proporsche's Avatar
sorry should have read the complete thing..my bad
Ivan
Old 06-04-2017, 09:35 AM
