-   -   Click / Tap Noise on decel 88 3.2 (http://forums.pelicanparts.com/porsche-911-technical-forum/958290-click-tap-noise-decel-88-3-2-a.html)
fastdiablo 05-29-2017 09:28 AM
I have an 88 3.2. the car just developed a click/tap noise that occurs when I left off the gas, happens about 70% of the time now. Sometimes it happens when I'm just cruising at a constant speed, but much less often. The sound is as if someone taps the passenger or rear window with a quarter or a key. "CLICK!". Thoughts? it's pretty annoying.. can't really tell where it's coming from, inside, outside etc. not sure where to even start. Thanks for any suggestions.
jlex 05-29-2017 06:01 PM
Is it a single click, multiple rapid clicks :confused:
75 911s 05-29-2017 06:10 PM
Start it up in your driveway and have a friend pump the gas pedal while you stick your head near the throttle linkage. See if you can reproduce the click while not moving.
fastdiablo 05-29-2017 07:29 PM
It's one click, not multiple.
proporsche 05-30-2017 01:20 PM
hi diablo..you really need to try to record the sound otherwise we will be guessing...
i have heard it all ,even loose hub cap could do the this noise...so, try to record it...
Also try to drive near some kind of wall it will multiply the sound...
Ivan
hcoles 05-30-2017 07:56 PM
sway bar mounts?
