Ferrariguyma's Avatar
Send a message via AIM to Ferrariguyma
Question How to install Cibie Hood lights? Do I have all the parts?
I bought a set of Cibie/Marchal hoodlights on ebay. I am trying to figure out if I have all of the pieces required to install them. I think I am missing mounting plates. They came with the housing, lens, innards and the bolt inserts. From my research on this list I see sets with black plates at the base. Do these plates go inside the hood or do they rest on top of the hood? Are there any rubber gaskets or grommets? or does the assembly attach directly to the top of the hood with the mounting plate attached to the underside of the hood?
Thanks for any photos, instruction or advice!
Andrew Conti
(6) cars currently in my garage:1976 Porsche 912E #627 Ascot Green 1986 Ferrari Mondial 3.2 Coupe Brown/Tan 1986 Porsche 911 Carrera 3.2 Paint to Sample Brown/Brown 1985 RoW Mercedes 420SEC C126 Coupe Brown/Tan, 1978 Alfetta GTV with a TwinSpark, 1997 BMW Z3 1.9 Boston Green/Beige 5speed
Old 03-07-2006, 06:11 PM
jtkkz's Avatar
Those black base plates goes inside the hood
Rubber gasket between hood & lights
pics of my cibies mounted
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 03-07-2006, 06:21 PM
Series900's Avatar
andrew, call the shop 603.863.0090 or email series900@nhvt.net
Damon @ SERIES 900.com
Sunapee NH
several 911 variants
Old 03-07-2006, 07:40 PM
charleskieffner's Avatar
where can i buy these style mounts? would rather use hellas due to better access to distribution here in phx.
Old 03-07-2006, 09:15 PM
project 911's Avatar
One more pic for you.
Steve B.
1971 T 2.2 w/Zeniths
Gruppe B member 171
Mid 9 Web Site Guy
Old 03-08-2006, 04:18 AM
did you make the backing plates? or is this a model of cibie specific to hood mounting? have not seen cibie here in phx in years. hella has pretty much taken over here with very large distribution and retailers. how much and how many relays involved? 1 per light, 1 relay per 2 lights? are they each switched? or on 1 switch? do you have diagram of wiring? thanks really interested in doing this!
Old 03-08-2006, 04:33 AM
Thumbs up Once again this list is amazing! THANKS!
Damon I left a message at your shop.
Thanks to all for the detailed photos. I am undecided which mounting location would look better on my SC. On the hood or on the front finder slightly inboard of the headlights. I am leaning towards fender mounting but I have no idea what might be involved in mounting them on the fenders. I assume the bumper comes off and allows access to the undersides of the fenders?
Does anyone have a picture or a good description of what the rubber gasket that goes between the body and the lamp housing looks like?
Sorry for being the Man of 1000 Questions!
Andrew
Old 03-08-2006, 06:09 AM
More pics from "woody's" car embedded within...one of MANY links to this topic on a search ( key words rally lights, hood-lights, hood mounted lights, Cibie, rally lights, etc, etc...)
Cibie hood-mounted lights
Forget Hellas, KC's etc..these ALL mount using a post, not a flattened bottom, and therefore also require a separate hole for the wire...which normally goes through the flat base of the originals....
- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 03-08-2006, 07:00 AM
will thank you. will begin search for elusive cibie's. like the one post said...................."chicks will dig them!" LOL! but numero uno...........i can hopefully see elk or deer raccoon jack rabbit etc. before they become my passenger. true story coming back from san diego one summer night in my scca datsoon 280-z at warp speed outside of gila bend, az. easily doing a cool 110mph when a very large jack rabbit(not a cottontail) and i wacked the hell out of him..............er he wacked the hell out of me. either way he was vaporized and my air dam, lower valance, a/c condensor and radiator were all taken out!!!!! and i got to watch sunrise come up w/a very late to work and pissed off girlfriend before i got ride into town for tow truck! cant have enough light!
Old 03-08-2006, 07:15 AM
jtkkz's Avatar
more pics
Old 03-08-2006, 10:19 AM
Yellowbird RS's Avatar
jtkkz & Steve please post some more pics.
X/A
Old 03-08-2006, 10:34 AM
jtkkz's Avatar
HI
what pics do you want to see?
Old 03-08-2006, 10:39 AM
Thumbs up THANKS FOR ALL THE PICTURES!
Does anyone have these lights mounted on the front fenders of a short hood? With underside photos?
Also ---
What does the rubber gasket that goes between the lamphousing and the hood look like? Diameter? Thickness?
Thanks!
Old 03-08-2006, 10:47 AM
Carl Bauer's Avatar
From
http://www.early911sregistry.org/forum/showthread.php?t=9772
Carl Bauer - 1979 RoW 911SC - Orange Bar Products
Old 03-08-2006, 11:57 AM
hey thanks started doing a looky see on web. aardvark intl. talked to gunther. name of lamp "oscar.porsche did actually use oscars OEM. mounting plate not supplied.............you make your own. stated mounting to crossmember best mt. point. if not backing plate must be fabbed. cost of oscar from gunther $125 each. super oscar too big he said. 90 % of all his sales of these are porsche's.
Old 03-08-2006, 12:07 PM
jtkkz:
The detailing of your wiring is commendable.... but a question...
is that a power distribution panel fabbed and located on the edge of the trunk lid? If so, are these "hot" areas exposed or covered? A small shunt can make these short-to-ground in a hurry.
charleskieffner ...your a bit hard to follow ( language style)...but Oscars and Super Oscars are post mount and are not the style of light that these are trying to be. No doubt, somewhere along the line...Porsche used Oscars...maybe for some rallyes.... but the size/mounting is wrong. Like I said...where do you plumb the wires with a post mount..and how do you keep a big heavy light stable on a sheet metal hood with a post mount ?
- Wil
here are some links I collected..there are more..
http://forums.pelicanparts.com/showthread.php?threadid=201289&highlight=Oscar
where do I get some "bug-eye" driving lights?
http://forums.pelicanparts.com/showthread.php?threadid=196687&perpage=20&highlight=oscar&pagenumber=2
Wil Ferch
Old 03-08-2006, 01:47 PM
wil just going by gunthers sales. you are correct on having to drill(YIKES) another hole! one is bad enough! was almost thinking about buying another hood from somewhere and keep my original. the backing plate is a simple fab job. was really wondering how these are wired up. 2 to a switch, 1 each on a switch, hooked to hi beams(that would be the best, only one motion on or off) my use would be only lonely highway stretches here in southwest .
Old 03-08-2006, 01:54 PM
Look at Early_S_Man post here...for pics on Oscars and Super Oscars on a hood...you can clearly see the stabilizer rods on the backside -->
- Wil
Wil Ferch
Old 03-08-2006, 02:03 PM
jtkkz's Avatar
[QUOTE]Originally posted by Wil Ferch
[B]jtkkz:
Hi Will
It is exposed, but all wires are covered with plastic covering, but I did went ahead and covered it all up completely for safety issues.
Old 03-08-2006, 02:24 PM
Originally posted by jtkkz
HI
all the car I want to see a 74-89 w/cibes
X/A
Old 03-08-2006, 02:29 PM
