Brake upgrade question again
Hi. Please hear me out I know this subject has been beaten to death but I am planning to do a brake upgrade using 964 calipers over the 930 rotors. I have searched and did not find the answer.
The question I could not find an answer to is, will the two piston rear caliper fit over the 930 rotors or must it be the later four piston rear caliper? Thanks Craig |
Here you can see a 4 suitably modified http://forums.pelicanparts.com/uploa...1496263650.jpg the 2 will provide better bias either will want a 23.8mm m/c |
Thanks much appreciated. I just wanted to be sure with regards the 2 piston caliper.
Regards Craig |
| All times are GMT -8. The time now is 02:47 AM. |
