Roger Hall's Avatar
New 911
I inherited a 1984 Carrera that had been sitting in a garage for 7+ years. 1st and 2nd were rough from day one. I changed the gear oil and found lots of little needle shaped filings on the drain plug. It ran much quieter but in less than 100 miles when I was slowly pulling out of a parking lot towards a stop sign then I shifted into first and all I could find was 3rd gear. Seems like I am looking at rebuilding the 915 gearbox. The car only has 61,000 original miles on it so I am a bit surprised but it is what it is. Any thoughts or suggestions?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 06-14-2017, 05:53 PM
Have you checked the shift coupler bushings, shift rod bushing and shifter cup bushing? After awhile these plastic parts have a tendency to disintegrate.
77 911s
16 981gts
Old 06-14-2017, 06:19 PM
Cars and Cappuccino
tdw28210's Avatar
Agree with Knock.. Check the connections and couplings before cracking open the 915. My shift rod ball cup had almost completely broken free in my 85. Someone with bigger huevos than me welded it back in place while still in the tunnel.... Next to the fuel lines.... Yikes
Old 06-15-2017, 03:59 AM
72911's Avatar
Shift Coupling
Yup,
Same thing happened to me while driving back from the vintage races in Watkins Glen last year. I had to stay in 5th gear for about 2.5 hours because I couldn't get into any other gear. The shift rod seal had been leaking and trashed the coupler bushing. It came apart in small chunks.
72 2.7 Driven!
Old 06-15-2017, 05:46 AM
Roger Hall's Avatar
Agreed I plan on going through the Shift linkage first but the bits of metal on the drain plug are a bad sign
Roger Hall
81 924 N/A
Old 06-15-2017, 06:05 AM
Peter Zimmermann's Avatar
If those metal bits are small gear teeth, then yes, it's a bad sign. If the metal is primarily "hair," then maybe not. If the gear oil was never changed that could be normal wear. A good linkage inspection is necessary because it sounds like you have a bushing/coupler problem. BTW; what kind of gear oil did you use?
Keep the Shiny Side UP!
Pete Z.
Old 06-15-2017, 08:31 AM
Administrator
Luccia at Pelican Parts's Avatar
Congrats on the inheritance! I believe we have some articles covering the shifting components so be sure to take a look (posted below). Would love to see some pictures of it as well, if you have any. There are many moving parts in the transmission, and they have a tendency to drop small microscopic metal particles into the oil. Can read more in our transmission fluid article here: Porsche 911 Transmission Fluid Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article. I also posted some Pelican threads below that might give you some additional input on the metal shavings.
Porsche 911 (1965-1989) Technical Articles - Pelican Parts
Too much metal on my tranny drain plug? Should I be concerned?
Transmission Problem: Metallic Shavings in the FLuid
Old 06-15-2017, 10:02 AM
