Low on power then it will light up
My situation is getting more frequent so now I need to look into it closer. When I start the 88 (100k miles on the clock) on a cold start after sitting for a day, 2 weeks or maybe longer, the car will start but struggles to idle. After about 2 minutes of me controlling the throttle so it will not die, it will idle fine. When starting to drive it, the car feels very low on power and is rough, as if it is down a cylinder or 2. after driving it for 5 or so minutes, it is as if you flip the light switch and it accelerates and drives as it should. any thoughts on where I should start to look? thanks in advance.
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 06-18-2017, 02:28 PM
Drive it more often. Italian tune up!!! sticky ICV?
Old 06-18-2017, 08:03 PM
76 911S Targa
How long between fuel fills? You may be running pretty old gas if you only drive it every couple of weeks. If you do not drive it often try to fill up with non-ethanol premium to avoid water in the fuel.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 06-18-2017, 09:33 PM
Sounds like the ICV. Do some searches and you will see how to test it, etc. i had similar issues a while back and that was the culprit.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 06-19-2017, 12:47 AM
T77911S's Avatar
temp sensor issue or related.
maybe a solder joint on the DME
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-19-2017, 03:56 AM
Like this^
Cylinder head temp sensor.
Old 06-19-2017, 08:31 AM
