Disconnected oxygen sensor
I have been driving my 1984 911 for four years without any problems. I decided to replace the O2 sensor and I found that it was not connected. I am unable to find the connecting wire that comes from the harness. Does this make any sense? The car had been fitted with an aftermarket dual exhaust by the previous owner.
Any help would be greatly appreciated.
Old 06-19-2017, 06:32 PM
I understand the cars run fine without this sensor connected. I disconnected mine and put a wide band o2 sensor in the bung. Runs the same.
84 911 Targa Carrera currently getting renewed
Old 06-19-2017, 06:36 PM
The car will run pretty much the same without the O2 sensor. It may run a little richer throughout the RPM range. This may give slightly better performance, and slightly worse fuel economy. I run without my regular O2 sensor also, and use my wide band for engine monitoring, just like Lake Guy.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 06-20-2017, 04:26 AM
Steve F's Avatar
Question
I have to ask, as I too, have mine disconnected, but does anyone know if this will effect the smog test that I soon have to do? 1981 SC
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 06-20-2017, 05:36 AM
proporsche's Avatar
Hi Steve..to pass the smog test you have to have it connected and in working condition.After the test you can again disconnected..
Ivan
Old 06-20-2017, 05:58 AM
Steve F's Avatar
Thanks Ivan.
Old 06-20-2017, 06:07 AM
While hunting down a running issue, I disconnected the O2 sensor and have not tested it nor replaced it as yet, smog tests are no longer required in MN. I decided running a little rich was better than lean, and I'm okay with the fuel consumption numbers that I'm seeing. To my understanding, the O2 sensor has a larger impact on newer models than our '84s.
1984 911 Coupe
Old 06-20-2017, 06:29 AM
nene's Avatar
I have run several smog test in CAL without connecting my O2 sensor in my Carrera and it
has always passed.
Old 06-20-2017, 08:03 AM
proporsche's Avatar
hi nene..interesting..i would not mind to see the smog results when you go for tests.
Maybe they, DMW have changed the requirements?
ivan
Old 06-20-2017, 08:36 AM
nene's Avatar
If I find them I will upload them, but according to the tech, all was fine.
Old 06-20-2017, 01:58 PM
