Interior light won't go off
At 11 Target that the interior light will not go off when the door is closed I have checked all connections from the door switches to the light everything is in place any suggestions
(man/dude)
Might be a stupid question - but it's not in the "always on" position is it?
A hint might be that if a door switch (which grounds the light to turn on the bulb), if failed, would turn on both lights. Same goes for a brown wire shorting to ground. So if it's just the one light staying on something is happening locally at that light, not systemically. Check to see that the male spade connector isnt bent. I had a glove box light that would blow a fuse every time it was put into the "switched" position because the spade was bent and was contacting the positive side, but only when rocked to one of the 3 positions. |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
M/y
What is the model year?
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
disband
the fixtures kinda "roll on & off" by pushing the lens to three difference positions as I recall. on always, off always, & on/off with a closed/open door. could you have bumped the offending light not knowing to an unfriendly "roll" position?
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 09-27-2017 at 05:12 PM.. |
disband
such a great design by the way. my ford fiesta switch broke like the third time I
"rolled" it on... it was yellow..
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
