Clutch slip 1975 911s
I have a 1975 911s I am sorting out after it's been sitting for a number of years. The clutch is slipping between 3k & 5k RPMs. Can this be addressed by adjusting the clutch cable underneath the car, as per the Pelican article? Or don't even bother, time for a new clutch.
Old 07-05-2017, 07:18 AM
New clutch, no questions!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 07-05-2017, 07:31 AM
Administrator
Luccia at Pelican Parts's Avatar
Any idea how many miles are on that clutch? Any other noticeable symptoms besides the slippage?
Does sound like it may be time for a new one. So, if it's time I'm sure our clutch article will be of use to you. Good luck!
Porsche 911 Clutch Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article
Old 07-05-2017, 08:35 AM
no other symptoms, it takes off fine just revs quickly btwn 3&5k RPM with out additional forward momentum
Old 07-05-2017, 11:54 AM
I would start with a full re-adjust of the cable. slacken off and start from scratch and then test drive.
Tony G
2000 Boxster S
Old 07-05-2017, 01:13 PM
76 911S Targa
As I recall you should have about 25 mm (one inch) of clutch free play. Pull the clutch all the way back with your hand, then press it forward until the free play stops. How much? If you don't have any free play, you need a clutch adjustment. If you have proper free play, it is time to pull the engine and have a look to determine the cause of the slippage.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 07-05-2017, 05:32 PM
It's a 914 ...
stownsen914's Avatar
There's always a chance the clutch has been oiled by a leaking crank seal or tranny seal. If you take 'er apart to do a new clutch, check for those, or you'll risk ruining the new disk too ...
Old 07-05-2017, 07:47 PM
+1 on probable oil contamination. A car that has sat for a number of years most likely has some sealing issues.
Old 07-05-2017, 08:03 PM
