echecsqueen's Avatar
help ID electrical components please 1966
I have the wiring diagram...but cannot ID can anyone help.?
1 - canister shaped plug with 3 flat prongs?
2 3 and 4 plug in things adjacent to each other aft of fuse panel
and to the right of a grounding point.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 07-03-2017, 02:51 PM
proporsche's Avatar
Hi..turn signal relay is my guess;-)
ivan
Old 07-03-2017, 02:55 PM
steely's Avatar
Is there anything written/stamped on that can?
Honestly can't see anything in the pic but wires and what look to be loom guides(?) for 2-4, but a 66/67 owner might recognize that.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-03-2017, 05:21 PM
There is something stamped on the canister but the PO spray painted all of the wires and relays black - so I can't really make anything out. Removing the black has been such a chore that I am trying to ID anything I can and just label it and be done....The black paint also makes it almost impossible to photo anything well.
Is a loom guide a rubber plug that wires go into? Square shaped? you can best see what I am asking about under "4"- -
Old 07-03-2017, 05:37 PM
Shaun @ Tru6's Avatar
I would post over on Early S, someone over there will know.
Tru6 Restoration & Design
Old 07-03-2017, 05:45 PM
proporsche's Avatar
Hi Queen as i said turn signal relay ..have a look here....
you can actually correct your wires with this picture
Ivan
Old 07-04-2017, 12:45 AM
ROW '78 911 Targa
timmy2's Avatar
Rectangular plugs are through dash connectors for signals, lights, ignition etc. the dash area devices/switches plug into them. In the schematic they are illustrated by 3 main areas of dashed lines.
The round one is the turn signal relay.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-04-2017, 01:33 AM
Thanks all of you!!!! perfect.
Ivan you are so lucky to have visible wires that you for the photo!!
Thanks for the explanation about the dash connectors.....seems obvious now but when looking at the totality of this mess of wires......
Old 07-04-2017, 08:57 AM
proporsche's Avatar
Hi queen...it is actually not my car ...i knew it was the turn signal relay so i google it and it is from pelican forum picture.I always like to use pics for explanation ...it is just too bad they sprayed the trunk with all the black color.
Ivan
Old 07-04-2017, 09:52 AM
Mark Salvetti's Avatar
Ivan
Marilyn,
This is actually a great idea. Google your question and then use Google image search to locate photos on other Pelican threads. For instance, I searched for 1966 Porsche turn signal relay, and found photos of the fuse box and wiring. Try this thread, it will probably help you ID a lot of your wires:
1966 high beams turn off the lights
If you haven't run across him yet, this thread will introduce you to Grady Clay. Grady is a legend around here, unfortunately he passed away about 3 years ago.
Mark
1979 911SC Targa
Old 07-04-2017, 10:24 AM
That IS a great idea. helps to have an idea for sure.
How about these two red wires together (arrow) running along with the speedo cable (circled). One of them is 7 V and seems to actuate the tach gauge BUT the tach is very jumpy.....
Old 07-04-2017, 11:53 PM
Does anyone know if there is a special reason for 2 separate ground wires to be spliced together a few inches off of the chassis ground (aft of the fuse box) in a 912 1966 - and then made into one wire? one is brown with white stripe (not factory trace) and one is regular brown - then once they are combined they have painted the wire brown with silver trace???????? it headed to the gauges from there where it was disconnected.....any thoughts?
thanks
Old 07-06-2017, 03:27 PM
Queen,
Do you have a stereo in the car? That red wire doesn't appear like anything factory.
Rutager West
Old 07-06-2017, 03:30 PM
no stereo...it looks to be coming off the engine on the drivers side and traveling to the trunk....i agree not standard!
Old 07-06-2017, 06:09 PM
Originally Posted by rwest View Post
Queen,
i posted more photos of this wire's course in queens outlaw thread. any help you can give me. Rutager, would be appreciated
Old 07-06-2017, 06:12 PM
