Redoing the ground in front of the battery 1988 3.2
Before
Half way through cleaning everything. Neat copper (?) plated ground area. Brass brushed everything so that it shined. Used Deoxit before assembly.
Finished with new ground cable and new nut.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 07-07-2017, 05:17 PM
Good job, however, it appears you substituted an insulated ground wire for the braided ground strap. My understanding is that a braided strap has more strands of wire than a regular 4 ga battery cable. These strands are also smaller in diameter. The many smaller strands have a greater surface area than the fewer larger strands. Electrons flow over the surface of metals not the core. The difference may in actuality be negligible, so I wouldn't worry about changing it now that the job's done.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-07-2017, 05:53 PM
ROW '78 911 Targa
timmy2's Avatar
A/C only for wire surface skin effect of electrons.
D/C flows through every part of the wire.
That is why a 16 AWG wire is rated 20 amps for D/C.
The cable for D/C at 500,000 volts is about 1/3 the diameter needed if it was an A/C circuit.
You will be fine with the new insulated cable.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-07-2017, 06:31 PM
ROW '78 911 Targa
timmy2's Avatar
https://www.allaboutcircuits.com/textbook/alternating-current/chpt-3/more-on-the-skin-effect/
Dennis
Old 07-07-2017, 06:47 PM
Thanks, Dennis. I learned something.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 07-08-2017, 05:58 AM
