-   -   Can't find anyone that sells points for '70 2.2t (http://forums.pelicanparts.com/porsche-911-technical-forum/962478-cant-find-anyone-sells-points-70-2-2t.html)
jcambo7 07-06-2017 07:43 PM
So I have checked pelicanparts, aircooled.net, summit racing, gpr parts, and local auto stores. None have the points that is on my dizzy. It's a bosch dizzy and the part number is illegible. The engine is a 1970 or a year up or down and I am not sure if the dizzy is from the same year as the engine either. All the points I have looked at attach 180 degrees opposite of mine. I appreciate any help I can get finding the points or if someone has a set I can buy from them.
Picture is for a reference if it helps anyone.http://forums.pelicanparts.com/uploa...1499395397.JPG
ddinham 07-06-2017 07:55 PM
I have a new set that I will send you gratis.
PM your mailing address and I will get them out to you.
Dana
http://forums.pelicanparts.com/uploa...1499396107.jpg
Trackrash 07-06-2017 07:56 PM
Aren't they the same as what '60s VW Beetles used?
jcambo7 07-06-2017 08:11 PM
I'm not sure if they are but it wouldn't surprise me.
kenikh 07-06-2017 08:15 PM
Pertronix is another solution
Sent from my Nexus 6P using Tapatalk
Jeff Higgins 07-06-2017 08:27 PM
It's really the only solution, as far as I'm concerned. You simply cannot buy good points anymore - there is not enough demand for them. Everything I own that originally ran points has now been converted to Pertronix, or whatever is equivalent and available fro the particular vehicle. Do yourself a really big favor - ditch the points.
jcambo7 07-06-2017 08:32 PM
It had pertronix on when I first bought the vehicle but fried three due to it being connected to a hot connection at all times on the relay board. I don't know if it was for the ground or not but the guy that built the engine decided to switch it back to points when I had him look at it cuz I couldn't figure it out at the time. I am just trying to get the car running again after it sitting for 3 years. I will try and switch it back to pertronix later.
Trackrash 07-06-2017 09:21 PM
O'rilley says they have them. List: Points & Condensers - 1970 Porsche 911 | O'Reilly Auto Parts
Believe it or not, I have been getting all the parts I need for my '67 Beetle from them on-line.
proporsche 07-07-2017 12:24 AM
The vw point are the same but not really .It is for a distributor shaft with 4 edges so it is softer then 911 points...the point for 911 have stronger spring on them
Ivan
i have a bag full of points if you need some i will dig up some i am sure...
Jdub 07-07-2017 08:47 AM
Parts Klassik?
Wayne 962 07-07-2017 02:28 PM
I'm fairly certain this is what you're looking for?
You have a later model distributor in there, to the best I can tell from your photo (1972 and later).
Distributor Points 90160296000 - Beru - Porsche - 901-602-960-00 | Pelican Parts
http://www.pelicanparts.com/catalog/...0-00-M47_1.jpg
-Wayne
Trackrash 07-07-2017 03:38 PM
OK, I just happen to have two distributors on hand. A '70 T, 0 231 159 008 on the left, and a '73 T?, 0 2311 69 008 on the right. The points are different. It looks like Wayne is correct?
http://forums.pelicanparts.com/uploa...1499467124.jpg
jcambo7 07-07-2017 04:22 PM
-Wayne
Thanks Wayne! When I went under a 1970 911T in the catalog it didn't show this one though...unless I was doing something wrong which is probably the case...
SWS911 07-08-2017 06:35 AM
A '70 T originally came with a Marelli distributor. Bosch was as far as I know a replacement. The "E" and "S" of the same era, '69-'70-'71, used a Bosch distributor and probably the same set of points for your 008.
