Can't find anyone that sells points for '70 2.2t
So I have checked pelicanparts, aircooled.net, summit racing, gpr parts, and local auto stores. None have the points that is on my dizzy. It's a bosch dizzy and the part number is illegible. The engine is a 1970 or a year up or down and I am not sure if the dizzy is from the same year as the engine either. All the points I have looked at attach 180 degrees opposite of mine. I appreciate any help I can get finding the points or if someone has a set I can buy from them.
Picture is for a reference if it helps anyone.
1973 Porsche 914 GT conversion 1970 911 2.2t engine E Cam Motor, S spec heads, carbs, intake, and pistons, 914-6 Air Cleaner covers, 73 911 front suspension |
I have a new set that I will send you gratis.
PM your mailing address and I will get them out to you. Dana
Under the radar
Aren't they the same as what '60s VW Beetles used?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-06-2017 at 07:59 PM.. |
I'm not sure if they are but it wouldn't surprise me.
3 restos WIP = psycho
Pertronix is another solution
Sent from my Nexus 6P using Tapatalk
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
It's really the only solution, as far as I'm concerned. You simply cannot buy good points anymore - there is not enough demand for them. Everything I own that originally ran points has now been converted to Pertronix, or whatever is equivalent and available fro the particular vehicle. Do yourself a really big favor - ditch the points.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
It had pertronix on when I first bought the vehicle but fried three due to it being connected to a hot connection at all times on the relay board. I don't know if it was for the ground or not but the guy that built the engine decided to switch it back to points when I had him look at it cuz I couldn't figure it out at the time. I am just trying to get the car running again after it sitting for 3 years. I will try and switch it back to pertronix later.
Under the radar
O'rilley says they have them. List: Points & Condensers - 1970 Porsche 911 | O'Reilly Auto Parts
Believe it or not, I have been getting all the parts I need for my '67 Beetle from them on-line.
The vw point are the same but not really .It is for a distributor shaft with 4 edges so it is softer then 911 points...the point for 911 have stronger spring on them
Ivan i have a bag full of points if you need some i will dig up some i am sure... |
Senior Member
Parts Klassik?
'78 Targa in Minerva Blue |
Author of "101 Projects"
I'm fairly certain this is what you're looking for?
You have a later model distributor in there, to the best I can tell from your photo (1972 and later). Distributor Points 90160296000 - Beru - Porsche - 901-602-960-00 | Pelican Parts ![]() -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Under the radar
OK, I just happen to have two distributors on hand. A '70 T, 0 231 159 008 on the left, and a '73 T?, 0 2311 69 008 on the right. The points are different. It looks like Wayne is correct?
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 07-07-2017 at 04:04 PM.. |
A '70 T originally came with a Marelli distributor. Bosch was as far as I know a replacement. The "E" and "S" of the same era, '69-'70-'71, used a Bosch distributor and probably the same set of points for your 008.
