The part numbers that begin with 900 are all DIN standard parts. Porsche published a cross reference back in the 60s, I think, at the time they were converting from a previous parts numbering system to the one you see today, which they share with VW/Audi. So for example 900.075.001.00 is a DIN 933 spec bolt, M5 x 8 mm, and anything beginning with 900.075 is DIN 933. The last two digits (eg, 00) indicate the material (first digit) and finish (second digit) type.
For your project, Trem, you can acquire quality DIN spec hardware in the US from sources like Bel-metric and Wurth USA, and it can make sense to do so if you're buying in at least some quantity (tens rather than singles). There are places that sell pre-packaged kits of common sizes, too. For the onesies, I'd stick with Porsche or VW/Audi. I wouldn't as a rule use hardware store fasteners for critical applications on a car: there is too much counterfeit junk out there. Good luck with your project!
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
Eng-o-neer
Interesting.
Thread I stumbled on...Someone detailed the early 911 fasteners: Porsche Fasteners - Nuts, Bolts, Screws and Washers Built a website for buying fastener packs here: https://www.thenewgarage.com/1965---1969-porsche-911-912 |
Ben is a good guy, met him at Hershey 2 years ago. He gave up the idea, couldn't get reliable plating and margins were low. I've done a lot of personal plating for him since then.
Tru6 Restoration & Design |
Eng-o-neer
I wonder if he would be willing to relinquish the specs he compiled. The world runs on open-source software, after all...
If you Pm me your email I'll send you an email of how to read the codes.
Sent. Hope it helps you.
2001 986 S Last edited by Puma; 07-10-2017 at 02:39 PM.. |
I also highly recommend Bel-Metric, as Shaun mentioned. I used them for most of the fasteners on my previous build. I would collect a list of all the fasteners I needed as I worked on the car over the weekend, submit my order via their website on Sunday night, and have the delivery by Wednesday - ready for the next weekend.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
+1 for Bel-Metric. User friendly website to boot.
Eng-o-neer
So finally got over to Belmetric and it is a fantastic source for metric fasteners. The specs they have are extensive, and make it much much easier to map Porsche descriptions to actual fasteners. A lot of them come in yellow zinc, too, if that's your thing. If only they had rubber/plastic washers...
Sure wish I'd taken a closer look before. Thanks! |
Another cool thing about Belmetric is how fast they are.
1982 911 Targa, 3.0L ROW with Webers |
+1 Belmetric. I got tired a chasing around trying to find good hardware that had the wrong finish and looked blah. I ordered a whole pile of yellow zinc plated washers, bolts nuts, etc. Took about 5 days to my door. Hardware looks really nice. Redid the new engine mounts.
Bolts, washers, nuts. I hate lockwashers.... New hardware but not plated New yellow zinc plated
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
