Can anyone identify this minilite style wheel?
Hi All -
Stumbled on this picture but cant find out any info on these wheels. Does anyone recognize them? Really like the look. Thanks - Scott S http://forums.pelicanparts.com/uploa...1499896693.jpg |
They look like BBS style 19 rims - a bit difficult to tell 100% from the angle.
Watanabe Racing...very nice, lightweight wheels from Japan.
I have them on my '72 "Estee"-tribute... |
Not BBS....more likely Watanabe Racing as docdan suggests
http://www.jdmlegends.com/?p=5335 http://forums.pelicanparts.com/porsche-911-technical-forum/642758-anyone-fit-jdm-rims-their-911-a.html |
Try this the do custom bolt pattern on the RS watanabe style wheels. However, offsets might be different unless you go wide. Cost about $600/wheel
RS Watanabe R-Type 16x8.5 -6 | motiveJAPAN RS Watanabe R-Type 15x8 +0 | motiveJAPAN |
I don't think they are Wats, the lips don't look right, not smooth enough. More like Rota RKR, I think.
Superlites, from Australia.
I was thinking Rota as well - but they don't do the 5x130. I looked at Superlite, but don't see anything larger than a 15, and the spokes are different.
Hmmmmm... Really like these. I just sent an inquiry to Watanabe. We'll see. Thanks! |
These are too big for a 911, but I think in a 17 (or 16) they would be sweet. Haven't found out too much on them - I believe these are 18 x 12 to fit a Mustang. Made in Australia by Wayne Grady the only info I have.
http://forums.pelicanparts.com/uploa...1499970413.jpg |
Try atara racing. I know rwb used atara racing (watanabe style) on their builds
Here you go - they are Watanabe-r-type.
If they are 16's with that tire, that car must be really low. I would like a more traditional side wall height, so will need to do some research on the offsets. From: MotiveJAPAN Sales <info@motivejapan.com> Sent: Friday, July 14, 2017 8:39 PM To: S Schroeder Subject: RE: 1977 Carrera 3.0 * Heya Scott, * Those are 16x8 +0 and 16x8.5 -6 in gold finish with machined lip. * Tires are 195/45R16 and 205/45R16 * It’s available in your 5x130 (use Custom Bolt Pattern). * They can be ordered from here : RS Watanabe R-Type 16x8 +0 | motiveJAPAN & RS Watanabe R-Type 16x8.5 -6 | motiveJAPAN Thanks, -Maxime |
Hi All,
Following up on this thread as considering using the Watanabe rims on a SC slightly below Euro height with 245/45 and 225/45 16s. I am concerned with the low offset, potential fender protrusion and fender to top of tire clearance: Watanabe Rear Wheel Spec: 16x8.5 et negative 6 Using Bill V's formula (Rim Width*25.4)/2 -ET: The hub to outer rim distance is 113.95 mm For Comparison: Recommended 9" ET +15 measures 99.3 mm The Watanabe rim will be outbound approx 15mm from recommended 9" fitment 8" Front Wheel will be 23-25mm outbound from recommended (ET 0 vs +25) Ride height and (reasonable) negative camber can help mitigate. Has anyone tried to use these wheels or opinions from the wheel experts? |
Anyone know the estimated weights?
Weights:
7.8 KG (R) 7.5 KG (F) |
I researched the R Types for my 89 3.2...both through Motive Japan and even emailed with the factory in Japan. They'll do custom bolt patterns but R Types are only available in 1 offset in each size, which wouldn't fit a NB car. You need turbo flares, or a turbo, to run these. I can't remember the users name, but someone in Australia had them on a Carrera with turbo flares and they looked fantastic....although he sold them on the forum here a few months back.
I ended up having a set of Rotiform MLW's built with sizes/offsets that Bill V. recommended. Super happy with the rears, but wish the fronts had some lip like the R Types. http://forums.pelicanparts.com/uploa...1549758312.jpg http://forums.pelicanparts.com/uploa...1549758312.jpg |
Thanks Billy - the car looks great.
Did you go 8 & 8.5 in 16"? |
Thanks tx996tt....they're 17". Fronts are 8" and rears are 9.5".
Need a set up track wheels and these look perfect. Just need to be sure they can clear Turbo brakes on a SC. Thanks! Dan |
| All times are GMT -8. The time now is 09:16 PM. |
