finally got a chance to do more work on car
took all parts to get powder coated:
window frames targa roll bar cover E-brake and installed new hardware shifter assembly pedal assembly with all new hardware as well from pelican parts and got the bronze set for the bushings.http://forums.pelicanparts.com/uploa...1527366022.jpg http://forums.pelicanparts.com/uploa...1527366261.jpg http://forums.pelicanparts.com/uploa...1527366388.jpg |
Enjoying this thread.
I just bought a 79 and plan a restoration in the future so will look to this for inspiration! You mentioned back in December you were going mostly stock except the bumpers. Bumpers are also on my replacement list. Do you know which ones or which vendor you are using? I am looking around for ideas. |
some more of the cabin I used POR15 with metal prep and and metal cleaner.
I sprayed the interior. first i grinded off all the rust and scrapped off all the padding from the floor pans.http://forums.pelicanparts.com/uploa...1527367669.jpg http://forums.pelicanparts.com/uploa...1527367757.jpg before and after pics http://forums.pelicanparts.com/uploa...1527368126.jpg before and after http://forums.pelicanparts.com/uploa...1527368212.jpghttp://forums.pelicanparts.com/uploa...1527368492.jpghttp://forums.pelicanparts.com/uploa...1527376404.jpg http://forums.pelicanparts.com/uploa...1527376476.jpg |
all panels were stripped with airplane stripper down to bare metal
we stripped all panels down to bare metal and the applied etch primer and smooth out and ruff surfaces the car will get some good base coat of paint and the one clear coat let it sit we sand then another coat of clear coat. to give it that deep shine
http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG http://forums.pelicanparts.com/uploa...1538446842.JPG |
more work
more work.
here is some finished base coat panels
this is the original paint color platinum silver. I will also powder coat the calipers. they are new and we lazy with the red paint that and will be fixed.
http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG http://forums.pelicanparts.com/uploa...1538448348.JPG |
sorry for some of the pictures are upside down.
some pictures are upside down i dont know why they got uploaded this way. but also will be ordering brand new seal for whole car from pelican parts.
up date so after grinding down to metal and etch primer and then base coat
go over car again for some imperfections and we put first coat of clear on the car. there will be three to four coats of clear going on the car. we will wet sand in between coats
http://forums.pelicanparts.com/uploa...1543672882.JPG http://forums.pelicanparts.com/uploa...1543672931.jpg |
first clear coat applied
http://forums.pelicanparts.com/uploa...1543673035.jpg http://forums.pelicanparts.com/uploa...1543673046.jpg http://forums.pelicanparts.com/uploa...1543673078.jpg http://forums.pelicanparts.com/uploa...1543673089.jpg http://forums.pelicanparts.com/uploa...1543673097.jpg http://forums.pelicanparts.com/uploa...1543673122.jpg http://forums.pelicanparts.com/uploa...1543673135.jpg |
more detail on engine build later
preping for second coat of clear
sand down the first coat of clear to get ready for second coat of clear
http://forums.pelicanparts.com/uploa...1553478526.jpg |
This is looking so good! Congrats. Can't wait to see you driving around St Pete, brother!
Inspiring!
more pics of sanding first coat of clear
| All times are GMT -8. The time now is 09:54 AM. |
