what the second coat of clear looks like
this is second coat of clear put on car. i will be spraying another coat of clear so total 3 coats of clear going on the car.
http://forums.pelicanparts.com/uploa...1554586294.jpg http://forums.pelicanparts.com/uploa...1554586304.jpg this is just clear no wet sand or buff touched this paint when i took this picture http://forums.pelicanparts.com/uploa...1554586334.jpg http://forums.pelicanparts.com/uploa...1554586423.jpg http://forums.pelicanparts.com/uploa...1554586432.jpg http://forums.pelicanparts.com/uploa...1554586448.jpg |
more pics
more
wet sanding third coat.
wet sanding with 3000,6000 then 12000 grit sandpaper then buff to a shine.
http://forums.pelicanparts.com/uploa...1571315979.jpg http://forums.pelicanparts.com/uploa...1571315993.jpg http://forums.pelicanparts.com/uploa...1571316003.jpg |
Seats done
The seats are done with new leather not leatherette. and also replace the old padding in rear seats to give it more cushion. OLD
http://forums.pelicanparts.com/uploa...1583498410.jpg http://forums.pelicanparts.com/uploa...1583498433.jpg http://forums.pelicanparts.com/uploa...1583498445.jpg http://forums.pelicanparts.com/uploa...1583498457.jpg |
headlights
finally got around to doing something. Here are the headlights with L.E.D lights.
New seals. http://forums.pelicanparts.com/uploa...1597507037.jpg http://forums.pelicanparts.com/uploa...1597507052.jpg http://forums.pelicanparts.com/uploa...1597507119.jpg http://forums.pelicanparts.com/uploa...1597507134.jpghttp://forums.pelicanparts.com/uploa...1597507161.jpg http://forums.pelicanparts.com/uploa...1597507178.jpg http://forums.pelicanparts.com/uploa...1597507227.jpg |
never ending
still ordering parts on top of partshttp://forums.pelicanparts.com/uploa...1597507297.jpg
Fantastic workmanship. What clear did you use?
looking forward to see a photo with the seats in the car. Combination of exterior paint and design of the interiour will be awesome.
Re-spray inside of cabin with POR15. The first time spray didnt look right.
I didnt like the way the POR15 came out first round it didnt look right or feel solid in the cabin floor pans. So had to sand it down again and I re-sprayed. here how they look.Way better then first spay feels more solid. Then I DynoMat the interior as well.
http://forums.pelicanparts.com/uploa...1602944725.jpg http://forums.pelicanparts.com/uploa...1602944733.jpg http://forums.pelicanparts.com/uploa...1602944745.jpg http://forums.pelicanparts.com/uploa...1602944756.jpg http://forums.pelicanparts.com/uploa...1602944785.jpg http://forums.pelicanparts.com/uploa...1602944799.jpg |
Dynotmat
Here is the DynoMat work after a few days of curinghttp://forums.pelicanparts.com/uploa...1602944893.jpg
http://forums.pelicanparts.com/uploa...1602944901.jpg http://forums.pelicanparts.com/uploa...1602944910.jpg http://forums.pelicanparts.com/uploa...1602944922.jpg http://forums.pelicanparts.com/uploa...1602944935.jpg http://forums.pelicanparts.com/uploa...1602944945.jpg http://forums.pelicanparts.com/uploa...1602944956.jpg http://forums.pelicanparts.com/uploa...1602944966.jpg http://forums.pelicanparts.com/uploa...1602944974.jpg http://forums.pelicanparts.com/uploa...1602944982.jpg |
some more pics of interior. plus more parts
sanded down the rollbar and painted it and also put some sealent for the fender and new seals by the cowell
http://forums.pelicanparts.com/uploa...1602945184.jpg http://forums.pelicanparts.com/uploa...1602945190.jpg http://forums.pelicanparts.com/uploa...1602945395.jpg http://forums.pelicanparts.com/uploa...1602945414.jpg http://forums.pelicanparts.com/uploa...1602945423.jpg http://forums.pelicanparts.com/uploa...1602945432.jpghttp://forums.pelicanparts.com/uploa...1602945482.jpg http://forums.pelicanparts.com/uploa...1602945489.jpg http://forums.pelicanparts.com/uploa...1602945505.jpg |
Missed this thread...excellent!
Vari-prime for self-etching first on bare metal 7704S for primer in white Chromabase for Color. :D |
part on parts on parts keep them coming.
more parts
plus I cleaned the front oil cooler and bought new lines as the old lines got very hard. clean the inside and out side of the oil cooler and epoxy the parts. then I clean the front end of the car and re-spray it. got new bolts. Before http://forums.pelicanparts.com/uploa...1602950110.jpg http://forums.pelicanparts.com/uploa...1602950132.jpg http://forums.pelicanparts.com/uploa...1602950152.jpg AFTER http://forums.pelicanparts.com/uploa...1602950176.jpg http://forums.pelicanparts.com/uploa...1602950193.jpg http://forums.pelicanparts.com/uploa...1602950204.jpg http://forums.pelicanparts.com/uploa...1602950214.jpg http://forums.pelicanparts.com/uploa...1602950224.jpg http://forums.pelicanparts.com/uploa...1602950234.jpg |
front end clean up
here is how the front end looks now http://forums.pelicanparts.com/uploa...1602950304.jpg
http://forums.pelicanparts.com/uploa...1602950314.jpg http://forums.pelicanparts.com/uploa...1602950322.jpg http://forums.pelicanparts.com/uploa...1602950330.jpg the small things that matter seal you dont see I have more receipts http://forums.pelicanparts.com/uploa...1602950372.jpg http://forums.pelicanparts.com/uploa...1602950390.jpg http://forums.pelicanparts.com/uploa...1602950399.jpg |
| All times are GMT -8. The time now is 09:31 AM. |
