MSD coil with Permatune box 911SC?
I am troubleshooting what feels like an intermittent misfire on an 83 SC. The car has an MSD ignition system and an MSD high vibration coil currently installed. I have a spare blue coil and permatune CD in a box as well.
I will check resistances based on this page: https://www.msdperformance.com/products/coils/performance_street/parts/8222 But I am also wondering if is it safe to test the permatune box with the MSD coil at some point? A previous search revealed the thread linked below, but that was for a 912 and I'm not sure if that same advice (don't do it) applies to this car/setup: MSD coil with a Permatune? Thanks! |
I am sure others will chime in but I thought you could run the msd high vibration 8222 coil with a permatune. Threads with John walker and warren hall on this.
Scott 1981 911SC Targa - Platinum Metallic |
Got it, found this thread: Compatible coil needed for Permatune Blue box 3 pin
Not sure if the difference between the 6-pin boxes and 3-pin boxes would matter here. Thanks! |
