Zenith Carb Testing
Can someone tell me where I can buy a small vial to measure the accelerator pump volumes on Zenith Carbs ? Anyone have an alternative ? I can't find one listed on Pelican.
Old 07-18-2017, 03:26 PM
1QuickS's Avatar
I had a pyrex vial for decades until I fumbled it.
I now use a insulin hypodermic with the tip fused closed & a wire to dangle it. The markings will fade in time so scribing them on the exterior is good to do when new.
The trouble is there may not be enough clearance between outside diameter of the auxiliary venturi and the inside diameter of the main venturi if it is the OEM 27mm diameter.
Paul Abbott
Weber service specialist
www.PerformanceOriented.com
Old 07-18-2017, 07:39 PM
Thanks Paul. I tried the 1 cc syringe. can't get it to drop far enough into the Venturi .
Old 07-19-2017, 08:36 AM
1QuickS's Avatar
I searched Pelican, Stoddard, Redline & Pierce Manifolds for the Pyrex vial & nothing.
Paul Abbott
Old 07-19-2017, 09:24 AM
Thank again Paul.. I ended up making a receptacle out of a straw. fused one end with a match. used a 1 cc syringe to fill it to the 0.5 ml level and marked it. trimmed the straw to make a small dipper. works like a charm. Brian
Old 07-19-2017, 07:16 PM
1QuickS's Avatar
Very clever!
Paul Abbott
Old 07-19-2017, 10:13 PM
VFR750's Avatar
You might check out "alfa1750" on eBay. They have all kinds of carburetors and parts. They may have one. I seem to remember I bought my test vial through stoddard back in 2011.
Old 07-20-2017, 03:20 AM
Puma's Avatar
Edmund scientific has every kind and shape of measurement device.
2001 986 S
Old 07-20-2017, 06:19 AM
Thanks guys.
Old 07-20-2017, 07:05 AM
Paul- what is the correct procedure for removal of the enrichment circuit. My micro switch has died. I've read different opinions on the forum. Brian
Old 07-20-2017, 07:18 AM
Maybe I should have said Disable the enrichment circuit.
Old 07-20-2017, 08:18 AM
