Power window relay location - 82 SC
I apologize in advance for not doing a thorough search but I'm at work, windows are down and not functional and a storm is brewing.
Can anyone point me to the relay for the power windows in an 82 SC? (preferably not behind a $%(#ing gauge).
Thanks in advance!
Old 07-27-2017, 06:25 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Check the fuse panel. Bet one is blown.
I don't think you have window motor relays. I will double check right now. Edit: Yes it does.
1981 911SC Targa
Old 07-27-2017, 06:28 AM
Probably the switch
Old 07-27-2017, 06:30 AM
Bob Kontak's Avatar
See post #10
911 SC Power Window Problem
1981 911SC Targa
Old 07-27-2017, 06:35 AM
proporsche's Avatar
Hi..your window relay in in front fuse box number five that is direction from the front of the car Take any other relay and replace it close the windows and get your self new relay
Ivan
better here
Old 07-27-2017, 06:41 AM
Ivan
better here
Wow, thanks for the quick responses guys! I swapped the horn relay for it and all is well, crisis averted!
Old 07-27-2017, 06:49 AM
proporsche's Avatar
cool , u r welcome..just one thing..do not get relay from China, buy only factory
Ivan
Old 07-27-2017, 06:59 AM
I have an 82 SC also and the same thing happened to me. Turn out to be just a loose connection to the switch. An easy fix in my case. Good luck!
Old 07-27-2017, 07:25 AM
