Power window relay location - 82 SC
I apologize in advance for not doing a thorough search but I'm at work, windows are down and not functional and a storm is brewing.
Can anyone point me to the relay for the power windows in an 82 SC? (preferably not behind a $%(#ing gauge). Thanks in advance! |
Fleabit peanut monkey
Check the fuse panel. Bet one is blown.
I don't think you have window motor relays. I will double check right now. Edit: Yes it does.
1981 911SC Targa Last edited by Bob Kontak; 07-27-2017 at 06:32 AM.. |
Probably the switch
1981 911SC Targa |
Hi..your window relay in in front fuse box number five that is direction from the front of the car Take any other relay and replace it close the windows and get your self new relay
Ivan better here
Wow, thanks for the quick responses guys! I swapped the horn relay for it and all is well, crisis averted!
cool , u r welcome..just one thing..do not get relay from China, buy only factory
Ivan |
I have an 82 SC also and the same thing happened to me. Turn out to be just a loose connection to the switch. An easy fix in my case. Good luck!
