Help identify my ECU
Hey,
Could anyone help identify this ECU Chip? Trying to figure out if it’s a 27c32a or a 27c16. Was told to lift up the sticker - i was hoping it would come off nicely but it's not. would rather not rip it apart as I'd like to sell the performance chip after I replace it. Pictures uploaded here Thank you! |
E-85 sippin drunk
Fixed it for ya
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Its an Intel chip # 85760
Intel® Xeon® Processor E5-4640 v3 The big chip below it is the math co-processor. The SKILL, software and devices to program that gen of E-PROMS is becoming rare. IMHO; See all those wire jumpers??? I believe the numbers you are speaking of relate to what combination of jumpers and components equal that ECU version #
1980 911 - Metzger 3.6L 2016 Cayman S |
83 911 Production Cab #10
Send them an e-mail Autothority Performance Engineering
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Why care what size EPROM this is? 99% sure it's a 27c32 because only very early versions used the actual 27c16. Even after the EPROM was changed to the 4K size 27c32 it only held less than 2K of actual data. The early code didn't need that much space.
But then again it doesn't really matter all that much. There is an 8K base code in the MCU and the EPROM holds some additional code and tables for the ignition and fueling. And that is certainly been modified by AutoThority. Only they know what they did to the maps. Short of reading them and comparing them to a stock chip you'll never know. Fact is your DME has the O2 sensor electronics installed and can be made into anything. It all depends on what chip you put in. Late U.S. spec., late ROW spec. with the 28-pin 8K EPROM or any custom chip or earlier code in the 24pin EPROM. Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Thanks!!! Jeff |
Dave |
