noise in 5th gear and only while under load
I have just recently started to hear a noise comming fom the rear of the car while in 5th and while giving it gas... it won't make or skip a beat while i sit and rev it .. but the noise comes back while In driving and only! in 5th and underload! ???? any idea's...
Eric,
Have you checked the oil level in your 915 lately? Or changed the gear oil, ever? ------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler |
what is the noise?
maybe your rpm's and speed are to low for that gear when you hear noise? ------------------ Daryl Planter 91C2 Targa |
yep Oil was just changed, about 300 and some change ago...Now the tranny oil I haven't changed yet I have only had the car for about 5 months and drive it daily and the Fella I bought it from said he had just done that but I was thinking of switching it the BLUE STUFF everyone talk's about they say it help's with many other shifting and noise issues... but i will try it and let ya know.. it simply has be baffled.
Thanks as always guy's Eric, 78 911sc |
Could it be detonation? Is you timing ok?
-Brad 80SC |
5th sits highest out of the gear oil and when the oil gets low, 5th suffers. galling results that swepco won't fix. if it was the ring and pinion, it would do it in all gears.
I have a noise also when it is in 3rd gear only. Like a high pitch hum. any clues
Eric,
By 'oil level in your 915 lately?' ... I meant: Have you checked the gear oil level in your transaxle? It is supposed to be level with the bottom of the filler plug hole in the driver's side of the case, with the car parked on a level garage floor. And, if it turns out to be low, my suspicions are that the damage John Walker described is the cause of the noise you hear in fifth gear. It takes a 17 mm Allen wrench or drive bit to remove the filler and drain plugs. ------------------ Warren Hall 1973 911S Targa 1992 Dodge Dakota 5.2 4X4 parts hauler [This message has been edited by Early_S_Man (edited 10-26-2001).] |
Man Guy's, I checked the level's on everything and all is well with them.. on the way home last night the noise made it's self known thru all of the gers and no it's very loud it is a rubbing noise.. grinding if you will.. under the car in the right rear.. not engine.. she rev's fine and and sound's great it is something else so I have stopped driving her until i can get under and check it out It's a grinding noise that is continuous now with every revolution of the wheel.. SO I'll have to crawl under there and look for a sign of wear....if you guy's have any helping idea's on places to look first please let me know... you guy's have always been MOST helpful to me..
Thanks in advance, Eric |
get up to speed where you hear the hum, and push in the clutch and coast. if it stays, it might be a rear wheel bearing. sometimes they don't hum much until you get the speed up.
| All times are GMT -8. The time now is 11:22 AM. |
