Grommet / seal part # for rear harness where it passes through the body
More specifically, I am looking for the Porsche part # for the rear seal / grommet that surrounds where the rear harness passes through the driver side passenger floor area bulkhead.
I've been through the PET parts list, can't seem to find it. Any know off hand? Thanks!
1967 912 (now w/ 50% fewer random holes in it) 911 w/ 3.2 1974 914 (3.2L swap underway) 1984 928s (S4 engine and suspension), 1987 928S4 |
Comes on the loom. How would you ever get it on a complete loom?
Well that was fast! Hope you had a good weekend John.
So it is part of the harness but is not sealing any more is there a best practice for sealing it up short of replacing the harness? 3M body sealing caulk (readily removable).
How about urethane windshield sealer? You could also find a grommet that would fit, then cut it, work it in place and use sealer.
I might have one
lorne m.
83 SC |
Thank you for the note, but I thought it was an interval part of the harness?
the grommet on my harness was loose so I can be replaces but as John said it probably came with the harness but it is not unique.
Lorne M.
83 SC |
Thanks-maybe you can post a picture when you get a chance over the weekend. Have a good night.
Here is what I have
Lorne M. ![]()
83 SC |
Thanks - will ping you via PM.
Have a good Sunday Loren
