-   -   low oil temp front oil cooler sensor p/n please (http://forums.pelicanparts.com/porsche-911-technical-forum/966720-low-oil-temp-front-oil-cooler-sensor-p-n-please.html)
911 tweaks 08-16-2017 09:53 AM
the oil temp sensor/switch in this carrera oil cooler has p/n 930.606.118.00 and turns on the cooling fan at 250 degrees F...!!! OUCH... too hot...
I can't find my notes of the lower temperature sensor... a lot lower temp same style sensor that screws into the front oil cooler...
thx in advance for any help... bob
911 tweaks 08-16-2017 01:15 PM
just found the bmw p/n for the 82 degree C sensor but this sensor has 2 male push on spade posts on top of it vs the one round male post on the porsche sensor...
Q: does anyone know if I used just one of the spade connectors on the bmw sensor, cut off the black molded female connector used for the porsche wire sensor harness and crimped on a female spade connector in its place to get me connected to one of the male spades, would this set up work...?
...The bmw sensor p/n is 61-31-13-64-272....
thank you...))
86 911 Targa 08-16-2017 01:24 PM
http://forums.pelicanparts.com/uploa...1502918598.jpg
http://forums.pelicanparts.com/uploa...1502918614.jpg
I installed this one about 15 years ago.
Nason P/N TT-E3A-197RQCGG
On Temp=210f
Off Temp=197f
Good luck,
Gerry
JRSIII 08-16-2017 01:33 PM
You need to connect both sides. Cut off the post connector on the black wire and crimp on a female spade. Connect it to one side. Cut off the ground connector that is bolted to the boss opposite the sensor, crimp on another female spade and connect it to the other side.
911 tweaks 08-16-2017 01:55 PM
Jr... sounds promising... did you do this set up or did you "hear" that your way works...?
Also. Is this circuit live when the ignition is turned off = I don't want the fan to keep running after has been shut off and kill battery/run till temp gets below the 180 degrees...?
Thx for the encouraging info ...
Gerry,
Thx also but not a low enough temp switch if I am thinking this thru correctly...
911 tweaks 08-16-2017 03:10 PM
Gerry, have we worked on another Porsche tech issue? Did u at some point work for trw?
86 911 Targa 08-16-2017 03:17 PM
Temp.
Gerry,
Your motor needs to see 200-210f once in a while to
evaporate the condensation in your oil.
Also, if you have a fan, you will need a relay+harness.
I updated our 86 accordingly.
As per a very good friend (previous factory mechanic).
Also a former 959 test driver.
Best,
Gerry
911 tweaks 08-16-2017 03:55 PM
Thx Gerry... as I just explained in my pm reply to you, the car has a factory front oil cooler and factory fan mounted to the cooler...
*** what I am trying to achieve is replace the factory sensor with a lower temp one as waiting till the oil temp gets to 250f before the cooling fan comes on is in my opinion and I would guess most people's too hot to let the oil get...
Thus, I need a lower temp rated sensor to replace what is in cooler now...
Also, if I am missing something here please chime in...
I agree oil needs to get hot to cook out moisture in it but waiting till oil fAn comes on at 250 seems too hi...
Any and all info welcome.
Thx
