Finhead
Well, that didn't work.... stripped seat bolt edition.
Hey there Pelicans.
In the process of removing the driver seat of my 3.2 to add a SW chip, I've managed to strip a couple of the seatbolts (even after being incredibly careful not to do so - the metal in the hex head is incredibly soft!). Soooo, off to the store I go for a set of easyouts. Within minutes of returning, I've already managed to break one of the easyouts off in one of the seat bolts. Any suggestions? These bolts are incredibly tough to access given that they sit down inside the seat rails AND have a seat sitting directly above them with very little room to apply different tools. I'm going to try and reverse the easyout out with a punch and a hammer and will try to notch the head of the seat bolt and try and break it loose with a screwdriver and hammer. Any other suggestions? Thanks! 2cam |
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
U can try cutting a slot in with dremel tool or hack saw then a flat bit screw driver. That's what I did.
87' 911 coupe- guards red/ linen leather Only thing better than owning one is driving it. |
Finhead
2cam |
FYI - not that it helps your situation, but I installed my SW chip in my '88 without removing the seat.
1988 911 Carrera, M491 Cabriolet 2016 Cayenne |
Finhead
![]() Texbike |
Functionista
See these a lot. Round hole means I'm walking it out with a hammer and chisel. Not that difficult. Use new bolts of the correct grade/strength.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
You don't need to take the seat out for that job.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 08-20-2017 at 09:03 PM.. |
@2cam: you have a picture of your fail pls?
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
did the same on my 930.
I tack welded the allen to the bolt, removed the bolt then cut the weld off and removed the allen. I put cardboard all inside the car to isolate the weld. had to do this quite a bit. did same on bolt for tranny oil pan on the MB, one of those screws that holds a brake rotor on, the bolt on a strut to remove the inards to install a cartridge. I don't know how I got along without a welder for so many years.
Finhead
I'll post one this evening when I get home. The easyout left a nice, jagged point sticking up. Quote:
2cam |
I had to drill them out....
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
