Delphos, Ohio! I have a bunch of family there. You have to be the only 911.
Or, you're so rich, money is no object. Take a gander at the prices... |
Many manufacturers are more concerned with customer complaints of brake squeal than rotor or pad life. Thus, they install softer pads to mitigate any potential noise. Who knows, perhaps softer cast iron rotors as well (?). I"m sure you've seen the spent pad material end up covering wheels and wheel covers.
And comparing rotor life on another vehicle isn't a good comparison with Porsche rotors. Most cars are underbraked with thin, small diameter rotors and small, single piston calipers. In addition, many/most car dealers typically replace rotors along with pad replacement. Preventative measures or to "pad" the repair bill. Installing new rotors is more profitable than time spent turning good rotors. You decide. As described, brake pedal pulsations can be due to a transfer of brake pad material onto the rotor surface. If that's the case, try a surface conditioning disc to remove. https://www.aaabrasives.com/catalogsearch/result/?q=surface%20conditioning#q=surface%20conditioning &idx=production_default_products&p=0&nR%5Bvisibili ty_search%5D%5B%3D%5D%5B0%5D=1&is_v=1 As for cheap rotors; yes, they're out there: Sherwood |
The phrase "false economy" comes to mind when describing an antiquated process to rehab a safety item that should probably be replaced. Oh, and the fact that the OP can't find anyone to do it pretty much confirms that the industry has rejected this process out of hand. If someone could make money at it, they would be doing it. |
Sure, you had Bubba who'd take your rotors below minimum in the past, but I don't think a passenger car would stress rotors enough to be a real concern. I've seen dozens of rotors ground down to the cooling fins that didn't explode. Maybe this why the industry stopped? Dunno. On a racing car, sure, R & R. But on a street driven 911, can't see truing up the face of a rotor a bad thing. People sometimes skip refacing and throw another set of pads on a worn rotor without a hitch. We've become such a throw away society...:) |
Should one replace rather than resurface flywheels too? How about automatically replacing tires after 5 years, regardless of condition, because the manufacturer suggests it? Paying more than the item or service is worth or deserves is wasteful. Again, it's your money and up to you. Sherwood |
Sounds tight to me, tight as a crab's azz that doesn't leak underwater. |
I looked at it from a standpoint that one rotor was only worn by .25mm from new. The other was only worn .50mm from new. So rather than piss away the money on rotors, I spent $25 to have the rotors turned and spent $60 on a low dust performance brake pad. All told, I'm still $19 to the better and should have brakes that function like new. |
Warped rotors are one thing. BTW, the labor involved to R&R a rotor (to turn or replace) is the same. The difference is between the cost of two rotors (e.g. $300 + shipping vs turning both for $30.). Would you be against DIY or have your tech to R&R for +$200 labor? Again, your choice (better to have choices). I pick and choose parts and processes depending on the parts and process. Hey, it must be great to have a bunch of cars as well as a big checkbook. Best wishes.
Sherwood |
Have you measured the runout on the rotors? How do you know they're warped?
To muddy the rotor-turning waters, the process to resurface brake rotors is similar to resurfacing flywheels and brake drums. Typically, a lathe tool is used to true the friction surfaces. However, the process doesn't account for hard spots that develop in the surface due to heat. In that case, the lathe tool will merely skip over the hardened work surface and result in an uneven cut. In addition, the lathe tool could also create a fine spiral pattern, much like cutting grooves in vinyl records (vintage playback medium for you young grasshoppers).
The result is that the friction material (brake shoes, brake pads) wants to act like a phonograph stylus and traverse the grooves until the mechanism restrains further movement. A clicking noise is symptomatic of such a phenomenon as a result of this. For that reason, resurfacing "connoisseurs" recommend using a motor-driven rotary stone, not a lathe tool, to grind a new frictional surface or if a lathe-tool is used, to break up the spiral pattern by working the finished area with a flap disc. Tell that to your new car dealer service manager. :) Sherwood |
The thing is there are a lot of rich guys on pelican. But most of us are not. Many of us have had old Porsche cars for years and we are not millionaires. There is no safety problem if rotors are within spec. The rotors you are driving on now are within spec. The bottom line is all the Porsche dealers and Porsche independents will not turn rotors because they make a lot more selling new ones. It is kind of like cheating the customer.
Easy there tiger, don't take my word for it - read Steve@Rennsports comments on turning rotors: https://rennlist.com/forums/911-forum/977018-turn-rotors-on-911-a.html http://forums.pelicanparts.com/porsche-911-technical-forum/397161-brake-disc-question.html http://forums.pelicanparts.com/porsche-911-technical-forum/491316-930-brake-rotors-thickness.html I'm certainly not advocating wasting money - my point is that there are things you don't skimp on -brakes and steering being at the top of my list, and that there are other marques that are more economical to maintain. |
Not sure what he's talking about. Stock thickness is 24 mm. Minimum is 22mm. I'm still above minimum even with the turning that was done. There's a reason they list a minimum thickness. Having brake rotors turned isn't really "skimping" IMO. I have had the rotors turned of almost every vehicle I have owned including an F350 that was used almost strictly for pulling a 3900lb trailer with machines weighing over 8000lbs. I have never suffered a failure due to turned rotors. I have OTOH suffered problems related to stuck caliper pistons and a brake line rupture. So if I were to call something "skimping" I'd have to say it's rebuilding calipers or driving around on old brake lines. |
He means 322 mm in diameter, not thickness. And calipers are meant to be rebuilt, hence the availability of replacement pistons and seals. Rotors are a known disposable part.
Don't get me wrong here. I'm simply going to end the myth here that rotors are supposed to be tossed. It's a silly notion that is based on no real fact. If all four brakes are working properly, there's no reason you shouldn't turn rotors unless their is noticeable bluing of the rotor meaning they have gotten WAY too hot. Then, yes, you get rid of them because they have lost some of the tempering. Otherwise, turning a rotor does not make them any less safe or places like Oreilly's wouldn't do it nor would the shop that did mine. |
On second thought though, I know most of the judges so... no, not really. The worst part is, I was a judge one year and STILL lost. :eek: |
Cab,
When I first read the thread, I was solidly in the "just buy new ones camp." Now, you won me over, I think since rotors have become so cheap, most of us just replace, or we've run them so long that they couldn't be turned safe. On the other hand is my DD Toyota which are probably cheaper to buy new than get turned and since I park it outside, they usually have a "nice" rust crust on the outer edge. One less thing in the landfill, well they do get recycled, but that takes energy too. Best, Rutager |
Yours aren't too thin, however. They just aren't working the way you want them to. Finally, back when Porsche made the rotors for your car, they were the only ones making them. If you wanted a replacement, they were probably $500 each from the dealer. Now, there are aftermarket rotors that cost next to nothing. What year is your car? Pelican has rotors for a 1983 for example, that are TWENTY TWO DOLLARS. That's right, 22 bucks for a rotor. Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI Why would you ever fcuk around with turning them when they can be had for 22 bucks? Just the bandwidth you wasted on this thread is worth 22 bucks alone. |
Please... don't hesitate to move along now and stop wasting your time. |
One more side thread for brake geeks
I asked if people thought the direction of rotor air scoops (in the middle of the rotor) mattered about a week ago on Cayenne forum (Early Cayenne Turbo's are HEAVY cars, big brakes) and I got a ton of opinions and learned more than I though I would. https://rennlist.com/forums/porsche-cayenne-forum/1005857-rotors-does-l-r-side-really-matter.html |
| All times are GMT -8. The time now is 12:57 PM. |
