Having a hard time finding someone to turn rotors.
I have been noticing a hum at a very slow rolling stop. I noticed my rotors have a slight drag that at a point on each side. The aren't warped to a point of causing braking issues. I assume the slight drag is the cause of the humming sound. I brought my rotors to Orielly's to have them turned but they can't get them to fit in their machine with the hubs off. Anyone else find it difficult to get rotors turned?
Chances are slim that you will get an accurate cut without hubs to center the rotors. Then there's the federal limit on how far undersize you can go. Cheap enough to just get new ones. Haven't turned a rotor in years.
+1
Turning these rotors is a waste of money, IMO.
You have been given sound advice. You also did the math.
First response by JW should have been enough. Just get new rotors if your diagnosis and assumption that the humming sound you hear at low speeds is the cause of your problem. End of story.
I get the rotors turned on every vehicle I own unless they are to a point they can't be turned and be within the safe limits. Why should my Porsche be any different when I drive it WAY less than any other vehicle I own? Do all mid 80's Porsche owners just toss rotors? Certainly there has to be someone who has had their rotors turned?? |
+1 on JW comment. But I would also add the one (anecdotal) and only time I have turned rotors was 20+ years ago on a BMW. Brakes were either ATE or Girling, so similar to Porsche. After getting turned (all within Federal spec), they warped within 500 miles. It was a 320i, so not like I was tracking it or being aggressive on the braking. Never done it since.
There is a reason why no one turns rotors anymore - they are CHEAP. If you have gone through all the trouble to take the damned rotor off in the first place, especially on a 911 where the hub needs to come off, why would you not put a new one on there?
OP, your car do what you want. The national chains will not turn them. Find a local machine shop, it will take awhile but I am sure you will find someone.
In the future, try not to stand on the brakes at stops if level put in neutral and let off he brakes to help prevent warpage. |
About 20 years ago I had the front rotors turned on my 75S. Car had classic warped rotor symptom of pulsing break pedal. The pedal and breaks were great for about 4 months then the old symptoms started to return, getting worse as time went on. I then replaced with brand name rotors, and all problems were solved for many, many years. Rob
Scrub them hard with Scotchbrite and put them back on. Lightly sand the pads on a very flat surface, and then bed them in. Flush out the old fluid while you are at it.
Work them. They like that. Porsche Perfection Paralysis. Don't go there. |
If you absolutely have to do this go to Toyota, or any large dealer really, that has a Hunter cutter that does it while rotors are still on car. Be prepared to do this again after awhile or one or two hard stops. No one cuts them as true as the factory did the first time.
You need to turn the rotors while they are bolted to the hub. The machine uses the bearing races in the hub to center itself in the lathe to make a cut perpendicular the bearing races. It is also possible that even a brand new rotor will slightly warp when torquing it to the hub. I've always put a finish cut on new rotors after assembly just to be safe. |
At the shop that I work for, we do not "turn" brake rotors. I work at a Mercedes Benz dealership in Washington, D.C. and the reasons we do not are #1 the manufacturer does not recommended it. #2, typically the metal in brake rotors for European cars is very soft & "turning" the brake rotors to get rid of any grooves or glazing takes way too much material off the surface of the rotor and as a result makes the rotor too thin. The reason the metal is much softer than what you find on a Japanese or domestic car is that when the steel rotor heats, the metal becomes very grippy with the brake pad and as a result, reduces the stopping distance. It's like that on purpose and you can go to any independent or dealership that specializes in Japanese, Korean & domestic cars and if they recommend replacing the brake pads, I guarantee they will also recommend resurfacing the brake rotors. Go to a shop that specializes in European cars, I'd be shocked if they even had a lathe to do that job.
Just a suggestion, before you take your rotors/hubs to an independent to have them destroyed, take a sanding wheel and sand away the hard shiny surface (glazing) to address the noise. Resurfacing the brake rotors will get rid of the noise but your cost will be a pulsation in the brake pedal because someone took too much material off and when the rotors heat cycled became warped and you end of having to get new rotors anyway. Good luck, let us know what happens. |
Just as an FYI, it's fantastically rare for rotors to actually warp. 99.9% of the time pedal pulsing is caused by uneven pad transfer. During braking, some of the pad material embeds itself into the surface of the rotor. This is totally normal and actually desired.
If you like to sit at stop lights with your brakes clamped hard, especially if the brakes are on the hot side, a little extra pad material can sort of stick when you release. Do this often enough, and you can build nice little clusters of pad material. To make things worse, the brakes are "sticky" in these spots which increases the odds of stopping on one next time, making those individual spots build little peaks of pad material n the rotors higher and higher with each stop. Best solution to avoid this is to not stand on the brakes anymore once you've stopped. Ease off on the pedal, use only enough pressure as needed. Even better is to roll ahead very slightly periodically to avoid being clamped on to the same spot. I agree with the above - a light cut might help you temporarily, but it's best to just go with replacement and change your braking habits. This part I'm not as clear on, but I guess the uneven heating you've created can change the metallurgy in the rotor unevenly, and that means your problem will come back. Good luck! |
Thanks for your input |
Brakes are thousands of dollars cheaper than a transmission rebuild. Don't downshift to save brakes. That is crazy. The brakes are cheap and easy to replace. In 20+ years of owning my 911 I have never warped the rotors and I have done over 100 autoccrosses.
For the $50 per rotor, it would be economically cheaper to swap out rotors. I assume your time running around dropping them off, waiting a few hours, and running around getting them back, only to have the thing last 3 moths... is false economy. My standard practice is if each rotor is less than $100, I throw them out.
I took my car to the shop I have used for 30 years and they turned all four rotors for $90. My car stops just fine.
If you want to keep using the rotors, get one of these and see if it addresses your issue. Works very good to "scrape" the pad material off. One challenge you may encounter is the splash shield/backing plate may be in the way of doing the back side. Not to mention it's a pain in the butt to turn the rotor by hand while you're holding the hone in your drill against the rotor
Flex-Hone for Rotors, Hone Tools, Flex Hones Get one at amazon or someplace else besides direct from the manufacturer. Direct from manufacturer pricing is way more than retailers. |
Soft Rotors
I found Michael Lang's post #17 very interesting where he states that the European cars use very soft rotors. My wife's '99 C230 Mercedes had the front rotors changed by the dealer with less than 10k miles, then I put two more sets of ATE rotors on before it got to 100k miles.
In 2000, my son and daughter both bought a new Saturn on the same day. When they were about a year old, I went to the local auto parts store that offered free brake pad replacement for the life of the car, and bought a set of front pads, thinking I would get a two for one deal when I had to start replacing pads. Boy was I wrong. One of the cars was totaled (with 80k miles) in the rain when my son hydroplaned off the street and hit a tree, and the other was sold with 90k miles. These cars had GREAT brakes, and to my disbelief, at about 80k miles, the front rotors had lost less than .005" thickness and just less than 50% of the pads. I never had to use the pads, and they were thrown in the trunk of the one we sold. Bob B |
I ended up getting the rotors turned by a local I mentioned in a previous post. $25 for the pair. Lowest cost for new that I saw was $104 for the pair. Savings: $79
The funny thing is, I had no idea I was starting such a controversial thread. |
We'll just leave this right here and add some laughs/levity to the controversy
http://forums.pelicanparts.com/porsche-911-technical-forum/733038-fellow-brake-nerds.html |
Even if you turn your rotors you will still need to bed the rotors. My brakes are like running into a brick wall.
Did you put a dial indicator on the rotors to check the runout? If the surface is blotchy it's a bedding issue, it's really easy to see with a flashlight. My Stoptechs have a satin sheen and to this day are uber predictable at all speeds. Add some heat into the rotor and pad and they are Velcro. The way brakes actually work is fascinating, it's not just surface friction that is doing the stopping. Hit a google search and read till your eyes bleed! http://forums.pelicanparts.com/porsche-911-technical-forum/867029-new-brakes.html |
I considered starting a "which pad" thread but I think I'm just going to wing it to avoid further controversy. Plus there's already a thread on that subject. Thanks for the input. |
JJ,
That's the thread I was looking at. UGH all it does it set me off on another tangent. The ATE ceramics look like they work best with the most rotors. The problem I'm having is determining which ATE pads are specifically ceramic. I checked this site and it doesn't list the composition of the pads as far as I can tell. |
When I was tracking my 951 I had the rotors turned three times before they were at minimum spec and I scrapped them. I had two sets and alternated between the two. Cost me $15 per rotor. Are you guys saying 911 rotors are made from different steel?
Doesn't look like they make it for our generation...
Give them a call you never know. https://www.amazon.com/Ate-604842-Disc-Brake-Pad/dp/compatibility-chart/B00700Y4AA |
:lol: :lol:
The shop that turned my rotors has an on the car rotor turning machine. I had pulsating braking shudder at high speed and it is gone now. Turns out the shudder was from the rear wheels. My rotors are still within spec.
Hey while we're at it does anyone know of a good source for whale blubber? My gas lamps stopped working, but there's plenty of life left in them and I don't feel like switching to those new fangled 'lectric lights.
| All times are GMT -8. The time now is 09:32 AM. |
